Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: 2012 GSA dies
  1. #16
    Mansfield,MA
    I would like to have it hooked up to a device and a check for codes/trends promptly after it quits. If at a dealer, a computer download of the “latest and greatest” of the current program- if it hasn’t been done in a while.
    Mod Squad
    2009 F800GS 1994 TW200
  2. #17
    DennyPink
    Mar 2009
    Fort Collins, CO.
    Quote Originally Posted by Bugman98 View Post
    I started thinking about the kickstand switch issue more, and while that may be the issue for the OP, as he notes that the bike dies at any speed, that's not what happens to me (or my brother's GSA). In our cases the bike dies whenever the RPMs are low and the clutch lever is pulled in. Typical scenario is coasting to a stop: Bike is in gear, pull in the clutch, close the throttle and it just dies like I hit the kill switch. It seems to die about 1 out of 25 times.If I remember to leave the throttle open just a bit or blip the throttle so that the engine RPM doesn't fall down to idle I can keep this from happening.
    Seems to me that if my problem were the kickstand switch it would/could happen at any time. Instead my issue is somewhat predictable. Thoughts oh wise ones?
    About once a month my 2007 RT would do the same thing. While coming to a stop, I would notice the tach needle dipped to 800 RPM, then go back up to the normal 1,100 RPM. Within a day or two, the engine would suddenly die as you have described, but would always restart immediately. I started using Techron, Sea Form, Star Tron, or any injection cleaner about once a month, and the problem disappeared! Once a year I use some Iso-Heet water remover. You might want to give it a try.
    DP
  1. Joe Cocker dies at age 70
    By womanridge in forum Campfire
    Last Post: 12-25-2014, 11:52 PM
  2. Replies: 15
    Last Post: 06-10-2014, 07:45 PM
  3. K100 dies going 60 MPH
    By orbitK100 in forum Flying Brick K-bikes
    Last Post: 06-28-2009, 01:39 PM
  4. Now dies when below 2000 RPM?
    By sailorlite in forum Hexheads/Camheads
    Last Post: 11-07-2008, 10:59 PM
  5. Engine just dies!
    By pablo in forum Oilheads
    Last Post: 09-29-2008, 05:17 PM
