Scarletswirl
A question to all electrical gurus out there. I recently purchased and installed an Omega 600W alternator. The kit comes with a 'bypass circuit' used to provide redundancy to the alternator excitation power in case the instrument panel GENERATOR bulb burns out. I have installed a Katdash on this bike and believe that each light is serviced by two LEDs. if I understand this correctly, then the excitation circuit should already have a redundancy built in via the Katdash, so the extra bypass provided in the kit is double redundant, if that makes any sense.
Am I correct in my assumption, or should I go ahead and install the bypass anyway?
Thanks,
Marc
Thanks,
Marc
