AntonLargiader
Active member
I'm reassembling a K75RT-P which is a bit of a project (some mixed ages of stuff, etc). I did not disassemble it.
The bike has ABS so there is a hard pipe running forward to just behind the steering head. It goes slightly to the right and points down, then has a rubber support grommet and transitions to flexible line. This is aligned with the rightmost opening in the RT radiator cover, but there is no support point there. Does it mount to the radiator?
