Results 1 to 11 of 11
Thread: Just changed my rear tire and the rim is damaged.
    Apr 2020
    Denver Metro
    Is this common?
    It just looks like a sharp edge was hit and not protected by the tire. It's holding air pressure and the tire tech said it was probably fixable. Anyone else do the repair? (I'm not doing it at this point because I can't feel it while riding and I don't hot rod anymore.) Was told $150 to repair is likely.
    Thoughts?
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    You are fortunate to live near one of the most respected wheel repair shops in the country. Get it fixed.
    Woody's Wheel Works
    2200 S. Jason St, Denver, CO 80223
    info@woodyswheelworks.com
    Phone: 1-303-936-0232
    Text: 1-303-578-9599
    Fax: 303.936.1992
    Kevin Huddy
    Never have more ambition than adhesion.
    Apr 2020
    Denver Metro
    Wheel change time?
    Might be the right time to change to a 17" wheel.
    JohnWC
    Akron, Ohio
    Quote Originally Posted by akbeemer View Post
    Woody's Wheel Works
    Fax: 303.936.1992
    Woodly's Wheel can probably fix it, although I would check with them on the details. I had a K75 three spoke wheel that was damaged and contacted them. I got some confusing advice such as , " Even if we straighten it, it will go back to being bent" and, " It will only be good for very infrequent riding if we do it". And on top if it, it was pretty expensive to have them do it.
    I then called MC Wheel in Arizona and got a completely different take on it. They could fix it, it would be fine to ride. The only thing that stopped me was the shipping cost of about $120 out and back, but the actual straightening was a reasonable $120-$180. Their phone number is 888-629-4335. I would give them a call. (Their website was in transition at the time, but it should be operative again, and they were formerly based in New Hampshire, but they have moved to Arizona.)
    Registered User paed's Avatar
    Jun 2015
    Archbald, Pa 18403
    Goggle MC Wheel. They are now in Arizona, used to be in NH. They've done the front wheel on my 96 R1100RT 2X's. They can repair some nasty bends to racing specs. And yes, the OEM wheels of this vintage are soft as butter. My rear now has a slight bend, and I'm diligent about keeping max recommended PSI. Of course, Pennsylvania's shoddy road maintenance and my 245 lbs are factors in my case.
    Mar 2013
    Winnipeg, MB, Canada
    Not to de-rail this thread but...........
    I need new tires and of course, the Michelin Pilot Roads are getting few and far between for the 18" rear.
    My rear rim is bent as well and could be straightened but I found a 17" from a K75 that is the three spoke cast.
    Is this a reasonable option?
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Quote Originally Posted by dieselyoda View Post
    The K75 wheel is probably 2.75" wide (the size should be cast into the back side of a spoke). If so it would be too narrow to fit anything but a 130/90 or 140/80 tire.
    Frank
    '17 R1200RS, '03 R1100S BCR#6/200, '85 K100/1100RS, '16 R1200RS (gone) '11 R1200RT (gone) '05 R1200ST (gone) '99 R1100S (gone) '96 Ducati 900SS/SP (gone) '92 K100RS (gone) 500,000+ BMW miles
    Feb 2005
    Trinity, NC
    5" K1200RS wheel fits, and you have to use the RS wheel bolts as they are shorter than the bolts for the 18" wheel. Early K1200LT wheel is also the same, so you might find a wheel from a front end totaled LT.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Jun 2015
    Archbald, Pa 18403
    I too am interested in finding a 17 inch for my 96 R1100RT. Hoping someone can chime in with best options. I know Paul G put a 17 on Voni's RS, but I haven't researched the subject. When I have time I'll blunder around this forum for more info.
    Apr 2020
    Denver Metro
    Been riding it.
    I've had a chance to ride the bike. It's a pretty minor side edge dent and no apparent wobble to the tire. I don't hot rod anymore and the bike feels solid. I'm inclined to just wear the NEW tire out and look for a 17" wheel from an older K1200 bike that fits. That said, I'm liking the Metzler Z8 tire.
    Apr 2020
    Denver Metro
    The 04 RT has the brake disk attached to the wheel
    The 97 has the entire rear brake assembly attached to the drive housing, so when removing the wheel, NOTHING has to be done with the rear brake. I really don't care about how many spokes as I don't ride anything to impress others and if I really cared about looks, I would wash the bike more often than ONCE A YEAR.
    I do care about function and I love the ease of rear wheel removal. I've had to do it twice. Once for a flat tire and once to replace the worn out rear tire. With more than 200K miles under my belt, I've removed enough rear tires to know what is typical and what is amazingly easy. I don't ever want to go back.
  1. Damaged Rear Wheel
    By dsimon9 in forum Wetheads
    Last Post: 08-07-2019, 02:35 PM
  2. Rear Brake Rotor 2009RT damaged
    By tgf429 in forum Hexheads/Camheads
    Last Post: 11-11-2013, 07:45 PM
  3. Tire iron removal of rear tire on R1200RT
    By alzyck in forum Hexheads/Camheads
    Last Post: 11-27-2009, 10:25 PM
  4. Replies: 6
    Last Post: 07-31-2009, 10:18 PM
  5. Changed my rear tire - No blood this time!
    By MotorradMike in forum Gear
    Last Post: 07-18-2009, 08:50 PM
