Results 1 to 10 of 10
Thread: F-Twins Tech - F800GS Front Wheel Removal
Hybrid View
    Jun 2009
    Rochester, MN
    The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
    The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
    It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
    Please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability. Here's a link where you can look up a place to dispose of your used fluids (oil, coolant, brake fluid, etc.) - http://earth911.com/
    This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
    PLEASE PRINT AND READ ALL THE INSTRUCTIONS BEFORE BEGINNING!
    Final note: The motorcycle's two wheels are the only thing keeping you upright. When in doubt, take your motorcycle to a reputable dealer.
    Removing and reinstalling the front wheel on your BMW F800GS
    Note 1: The specific bike shown is a 2013 F800GS
    Note 2: The tools and materials used are by personal choice and are not due to any affiliation with any brand
    Tools Required:
    - T30 star (Torx) bit
    - T45 star (Torx) bit
    - E12 external star (External Torx) socket
    - 17mm socket
    - Ratchet(s) that fit the above
    - Torque wrench
    - Suitable way to raise the front wheel and keep the bike steady.
    Jun 2009
    Rochester, MN
    If your bike is equipped with an Anti-lock Braking System (ABS), begin by using your T30 to remove the bolt that holds on the ABS sensor to the fork (noted by the red arrow). This is a sensitive electronic part, so care should be taken. The sensor does not have to be completely removed from the housing, it sensor just needs to be pushed back far enough so that the wheel/rim does not damage it as we remove the wheel.
    Jun 2009
    Rochester, MN
    Using your 17mm socket, loosen (but do not remove) the axe bolt on the clutch side of the motorcycle (indicated by the red arrow). Then using the T45 star bit, loosen the four axle pinch bolts (two on the clutch side and two on the throttle side) as indicated by the green arrows.
    Jun 2009
    Rochester, MN
    Using a suitable way to raise the front wheel of the bike, lift the front wheel. In this case, we are using a motorcycle lift underneath the bike's bash plate, with the rear of the bike secured. A car jack or bottle jack may work for you. Please make sure that however you lift the bike up, it's done safely!
    Jun 2009
    Rochester, MN
    I find that it's easiest to use the nearly-unscrewed 17mm bolt on the clutch side of the bike to push the axle out towards the throttle side of the bike. This exposes enough of the axle to remove it all the way by hand. Be careful to support the front tire as you gently remove the front axle as not to damage the bearing seals.
    Jun 2009
    Rochester, MN
    Note that the clutch side of the bike contains a spacer that may stay in place as you remove the wheel. Most of the time, in my experience, it falls out and tends to roll under the farthest depths of your workspace. This spacer should be inspected, making sure there isn't any pitting on the metal surface. New spacers should be purchased if there is deep pitting.
  1. F-Twins Tech F650/700/800 - Battery Removal
    By drneo66 in forum F-Twins DIY/Tech Library
    Last Post: 01-17-2021, 02:16 PM
  2. front wheel removal GSW
    By carrell in forum Wetheads
    Last Post: 05-30-2015, 10:47 PM
  3. '08 RT front wheel removal
    By pch123 in forum Hexheads/Camheads
    Last Post: 03-29-2010, 01:12 AM
  4. Front Wheel Removal
    By ERIC1514 in forum Flying Brick K-bikes
    Last Post: 09-22-2005, 10:45 PM
  5. Front wheel removal
    By Win3855 in forum Flying Brick K-bikes
    Last Post: 06-25-2004, 12:19 AM
