Results 1 to 15 of 26
Thread: Cleaning aluminum
    Registered User AjaxTheDog's Avatar
    Jun 2013
    Highlands Ranch, CO
    Blog Entries
    Cleaning aluminum
    Has anyone had any luck cleaning the mottling off old aluminum parts? I have tried soda blasting, aluminum jelly and polishing compounds with little luck. Parts look cleaner but still have a mottled rather than bright shiny finish which they had when new. I'd like to get as close to that as possible. aluminum.JPG
    Bill in Highlands Ranch, Colorado
    2017 R1200RT
    2007 Eton Beemer Scooter
    Liaison 20774's Avatar
    I've never had to deal with that issue so far, but I notice some threads in the Similar Threads pane at the bottom of the screen...maybe there's some ideas there.
    Jun 2013
    Highlands Ranch, CO
    Blog Entries
    Yup, already looked there. Nothing on this.
    2017 R1200RT
    I can't quite get a good view of the problem. You said soda blasting didn't work. There is more aggressive blasting like with walnut shells. I've also heard about vapor blasting. There is a link in the Opportunities thread where a member was discussing this procedure:
    https://forums.bmwmoa.org/showthread...-Blasting-quot
    Here are some other vapor blasting discussions:
    https://forums.bmwmoa.org/showthread...one-tried-this
    https://forums.bmwmoa.org/showthread...ne-cases/page3
    Jun 2013
    Highlands Ranch, CO
    Blog Entries
    Guess I will have to try the vapor blasting route. A local guy does it for $75 an hour. Hopefully he can tell me what level of success to expect before starting the operation.
    2017 R1200RT
    Mar 2018
    Upstate, NY
    Vapor blasting, Brook Reams, etc.
    Hi there-
    I have had great success in utilizing vapor blasting, especially on things like heads and cylinders. The finish looks factory new. The problem, of course, is that it's not always convenient, or practical, for things like an assembled engine case....
    Brook Reams gives a really nice overview of his aluminum cleaning practices on his website. The real trick in some of those methods is time. A lot of time....
    https://brook.reams.me
    Good luck!
    ECJ
    '14 R1200 GS Adv bigjohnsd's Avatar
    Oct 2018
    Black Hills, SD
    Quote Originally Posted by ecjjce View Post
    Hi there-
    Good luck!
    ECJ
    Brook Reams Refinishing Techniques/
    AutoSol Motorcycle Products
    The only dumb question is the unasked question!
    Team Pterodactyl - When we ride, we ride!
    Boise, ID
    Simple Green Aircraft Precision Cleaner
    You might want to try Simple Green Aircraft Cleaner. It is designed to clean aluminum on aircraft but not damage plastic or paint. A good friend of mine who restores old BMW bikes says it gives great results. If you look at the reviews of this product at the Amazon link below there are some user photos of results from using this product. I'm going to try it on a /5 I'm refurbishing once it warms up here in a month or two.
    https://www.amazon.com/Extreme-Aircr...s%2C229&sr=8-1
    Greg Feeler
    Ambassador & 2022 BMW MOA Rally Co-Chair
    Sep 2013
    Central Maine
    1500 or 2000 grit sand paper and then polishing compound?
    http://www.chinook-helicopter.com/ma.../cleaners.html
    Apparently, Simple Green does not advertise that the Army had to publish multiple stop use bulletins to keep Army Aircraft maintainers and pilots from using it. It was corrosive over time and would weaken and soften magnesium, aluminum, and titanium; basically any of the alloys. If memory serves, we had at least one catastrophic structural failure that was “present and contributing” in the findings to simple green use.
    FWIW I have personally seen the damage to metal caused by Simple Green in the 90’s both on my aircraft and my car (mag wheels).
    R. Reece Mullins Ebony R1200RT (Gretchen)
    MOA # 143779
    MOA Charter Club #5 #364 #100
    BMW MOA President
    Boise, ID
    Quote Originally Posted by rangerreece View Post
    Reece,
    That warning message appears to be very old as it references a crash in 1992. I suspect they are talking about traditional Simple Green because they did not state "Simple Green Precision Aircraft Cleaner" which is this product's name, and I would expect high precision in statements about aircraft maintenance. Simple Green Precision Aircraft cleaner was not introduced until about 2004 from what I can find, so I suspect that it was developed specifically to address any problems with their traditional product in this application. Is there any way you can find out the date of that warning?
    Greg Feeler
    Boise, ID
    Quote Originally Posted by GREGFEELER View Post
    Reece,
    P.S. I did see that at the bottom of that linked page it says it was last updated 1/7/2021, but that appears to be for the whole site, not necessarily the Simple Green warning page. But, I sure would like to know how old that warning is, and which Simple Green product it refers to.
    Greg Feeler
    Mansfield,MA
    I have found that when "staining" that resists the regular "cleaning" methods don't achieve the desired results, the "staining" has migrated into the pores of the metal. Industrial methods are needed as the top lays needs to be removed which can sometimes open the pores of the metal to even faster staining, oxidation and discoloration. Copper that has been outside for a while, and cleaned bright, will almost oxidize before your eyes.
    I took a quick look and this thread gives a quick overview of metal polishing-
    https://www.kmstools.com/blog/metal-polishing-101/
    It's important to "seal" the finished product to protect it. Sharkhide metal finish has had some great reviews although is very specific in it's steps on application. The marine industry has been battling this staining/corrosion for ever.
    Mod Squad
    2009 F800GS 1994 TW200
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Was that the Extreme Simple Green made for aluminum?
    Lee
    2016 R1200RS
    MOA # 30878
    Greg: I was unaware that Simple Green created a new product since the 90’s.
    Lee: we were using “original” simple green... that was the culprit.
    MOA # 143779
    BMW MOA President
  1. Suggestions for Cleaning an Aluminum Tank? '89 K75
    By 185193 in forum Flying Brick K-bikes
    Last Post: 05-01-2021, 04:30 PM
  2. Aluminum Cleaning
    By PeoriaMac in forum Airheads
    Last Post: 06-19-2009, 02:23 PM
  3. R75/6 cleaning engine aluminum
    By ripperfarms in forum Airheads
    Last Post: 08-20-2008, 11:49 PM
  4. Bare aluminum cleaning
    By JOHNP in forum Airheads
    Last Post: 07-28-2006, 02:10 AM
  5. Cleaning aluminum block
    By Tom Donnellan in forum Airheads
    Last Post: 12-06-2004, 05:00 PM
