Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Thread: U-Joint repair was worth it
  1. #31
    Mansfield,MA
    Quote Originally Posted by 31310 View Post
    Having difficulty getting the driveshaft u-joints replaced. Local machine shop, with an excellent reputation, says that since I'm insisting on non Chinese parts, nothing is available and that my only option appears to be buying new from BMW. The shop can do the work but with cheaper Chinese parts. They cautioned not to expect more than maybe two years service, certainly not that of original, they don't recommend or even want to do the work with sub standard parts. I chose this shop based on sterling recommendations from people I know who deal with them.
    To those who had their driveshafts reworked, any idea of the origin of the replacement parts? Or perhaps someone knows part numbers of U.S. or European manufacture. This process has not been, to date, smooth and any help would be great.
    Where were the original u-joints made? Most anything from the Eastern Bloc will be plenty durable is what I have found.
    Mod Squad
    2009 F800GS 1994 TW200
  2. #32
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Have you tried to source the Elbe 106? It appears to be the u joint of choice for the BMW shaft.
    https://www.drive-lines.com/elbe/tem...ies=ELBE%20106
    Elbe is a German company.
    I read the they are available at Pats Driveline in Canada
    How to:
    https://advrider.com/f/threads/2010-...ow-to.1444742/
    Ufda happens..........
  3. #33
    The Blue Max 31310's Avatar
    Apr 2008
    Calgary Alberta
    No idea where the original parts were made. Thanks for the tip about Pat's Driveline. There is a branch here in Calgary which I will contact tomorrow.
    2007 R1200RT
  4. #34
    Feb 2008
    Read thru the ADV thread
  5. #35
    Apr 2008
    Calgary Alberta
    Read the thread and although tempting, (thanks to the forum, successfully rebuilt the final drive four years ago) will follow the advice of a thread poster and take it to the professionals. Your reply encourages me that, as usual, there is a solution.
    2007 R1200RT
  1. u-joint inspection
    By johnkuhn in forum Airheads
    Last Post: 03-05-2012, 05:52 PM
  2. U joint repair
    By protomike64 in forum Airheads
    Last Post: 12-18-2011, 04:46 AM
  3. Ball Joint gone bad?
    By devauxb in forum Oilheads
    Last Post: 02-25-2010, 12:03 AM
  4. FD U-joint removal
    By JerryAttrick in forum Oilheads
    Last Post: 12-30-2008, 04:46 PM
  5. Need to replace U joint
    By electblue in forum Airheads
    Last Post: 04-18-2008, 03:21 AM
