Preventative maintenance?
georgebarthel
Hello all,
I have an '82 R100RT on the lift. It's likely to stay there for a period longer than I prefer. The time to spend getting it running and rebuilt is always longer than one anticipates as we all know! I give myself a conservative 6-12months.
Is there anything that one might do in order to keep the the pistons comfortable in the cylinders? With other bikes in my past, the pistons were oriented vertically. Thus a tiny amount of oil into the cylinder from the plug opening was logical. With the boxer orientation, I was wondering of the same held true??
Thanks in advance all!
-GB
I've heard that the cylinders should be put at TDC just to help from allowing a lot of moist air to get onto the cylinder walls. I suppose you could spritz some oil in through the spark plug hole at some intervals. Of course, that long, you should put some fuel stabilizer in and likely drain the float bowls.
Life...
It's probably life, not the build, that might extend the schedule.....which I think most of us can relate to. I know I certainly can!
ECJ
for sure understand about that life stuff...........takes forever the older you get so GET ON IT..........:laugh
Doesnt hurt a thing to squirt a bit of oil in the plug opening and then roll over the engine by turning the rear wheel a couple of turns with the trans in 4th or 5th............GOOD LUCK....
Thank you, much appreciated. The carbs will be getting a full detail, they're already drained. The tank as well will need a refresh. Planning on a full treatment from these fine fellows. http://gastanklining.com/index.html
Thank you Dennis, great advice!
Fogging oil...
+1 on the fogging oil (as opposed to regular oil) suggestion. It clings to the cylinder walls, and will not run off as easily. I use it at the start of every winter hibernation on my bikes....
Good luck,
ECJ
Gear?
Hello again Dennis, quick question. Could the transmission be in 1st for this procedure? I ask only because the bike is well torn down, the clutch cable and lever are removed. I am thinking I can get the trans more easily into 1st, and back to neutral?
Thank you,
George
