Incandescent tail light (1157) to LED conversion
TheRock58
TheRock58
2007 R1200 GSA
Is there a plug and play conversion from an incandescent tail light to a LED? The GSA has a CANBUS electrical system, would it confuse the CANBUS?
Thanks,
Be careful, an 1157 fits but is a bit different from the German equivalent with pin placement. So I’ve heard here :brow
:laugh :laugh
There was an optional OEM upgrade in 2008
Kinda BMW pricey and I thought it was NLA on parts fiche
I have the optional LED on my 07 R12 S, a different model but no effect to Canbus
Have tried some of the LED bulbs in sockets. Looks like a small red circle in middle of lens... worse lighting of whole lens.
Easier, for me, to add Skenes or Hyperlites alongside license plate... added bonus of increasing visibility.
Maybe cheaper alternative as well!
If your stock bulb is an 1157, then a "plug'n'play" LED (as available at any auto parts store these days) would draw much less current. That would probably throw an error code on the computer, thinking that the bulb is out.
The "fix" (and I use the term loosely) is to put a resistor in parallel with the bulb, so the circuit goes back to drawing the higher current again (which is wasted as heat). So you gain Nothing except the faster "On" time of the LED.
And I agree whole-heartedly that these plug-in LED replacements do NOT fill up the lens... Don't bother.
Thanks, good information. Wow, BMW is really proud of that tail light assembly!
I do have Hyperlights, but I've never been impressed with the stock tail/brake light set-up.
Does anyone know if there is a difference in the bulb pins? The BMW bulb, 07 11 9 905 511 LONGLIFE BULB - 12V 21/5W, retails for $8.87. I'm not sure about the 1157; however, it's a little hotter at 12V 27/8W.
I guess I'll leave well enough alone, thanks again.
There's not.
The bulbs with 120 degree pins are the amber single filament bulbs PY21W ... to prevent you putting clear bulbs behind clear lenses, yellow bulbs behind yellow lenses.
German bulbs are always higher quality than 'merikun FLAPS bulbs and are worth the higher price since you will replace the cheapo bulbs more often.
Kent, thanks for the information on those bulb pins.
If I recall correctly, I had a problem with the OEM bulb. For some reason it was vibrating in the light socket. So I replaced it with the 1157. I'll put that on my list for Spring maintenance.....
Thanks again,
2007 R1200 GSA
Thanks,
1157 bulb has two filaments and two pins to align it in the socket correctly, the pins are offset. 1156 is single and can be changed to amber. Hope this helps.
I tried to put LED's in my 2010 RT, not sure if same bulbs, but mine were basically a US 1156 bulb, single filament. Bulb is both tail lamp and brake light. Seems like what BMW does is increase the voltage or current from lower to higher when putting on brakes so light gets brighter. When you use an equivalent LED my understanding is the frequency or flashing of the bulb gets faster so the bulb appears brighter. I think the CANBUS does not see a change of resistance in the bulb and circuit and so as a tail lamp the LED bulbs seem to work fine, but as soon as you hit the brakes you get a CANBUS light error as if the lamp is out. If you shut off the ignition, it gets reset and the error goes away on key on and running, but as soon as you activate brakes you get error again.
I've tried several LED bulbs including those that listed as CANBUS compatible but no luck. It seems the way BMW uses these single filament bulbs as dual purpose bulbs there is no way to trick the CANBUS and make it work. I resorted to finding the best quality high contrast regular bulbs I could find to put in housing and adding some SKENE LED lights to supplement these.
Otherwise I have been able to replace all lights on my bike with LED bulbs as others are either on or off, so as long as the resistance of bulbs mimics the OEM bulbs you don't get a CANBUS error.
2007 R1200 GSA
Thanks,
