Results 1 to 12 of 12
Thread: Cold acceleration
    CAL0987
    Oct 2010
    Pahrump NV
    Cold acceleration
    I have a 1998 F650 that i noticed lately as it has gotten colder out that the acceleration is very sluggish.
    It gets better as the engine warms up.
    Definitely much better when the choke is on, which is needed to even get it to drive.
    But I noticed today that even after riding for 30 minutes and letting the engine warm , that when i turn down the choke, that the acceleration is still lackluster.
    When I turn the choke back up it accelerates like i feel it should.
    And i don't think i should drive with the choke on all the time!
    Carburetor adjustment needed?
    Something else?
    Just serviced the carbs , but did not make any special adjustments, except idle to factory spec.
    Quote Originally Posted by cal0987 View Post
    Something else?
    There is an often cited rule: go back where you were last. It sounds like with the choke off it is running lean but using the choke enrichens it so it runs better. So I would check for partially clogged jets or some other reason it is running lean.
    CAL0987
    Oct 2010
    Pahrump NV
    Replaced the jets when i did the carbs.. at least i think i did... i assume they come with the carb kit.
    I also put in an inline fuel filter after the tank valve?
    Is there something i can adjust to change the Lean?
    Idle mixture is adjustable. Fuel level in the float bowls should be checked. If it is too low the bike wil run lean. Fuel float level is adjustable.
    I would verify that the needle jet and is correct for that bike. I am not sure if the needle position is adjustable on those carbs but if so raising the needles one notch might fix it.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    This exchange is a demonstration of the corollary to the quote in Paulís signature line (The greatest challenge to any thinker is stating the problem in a way that will allow a solution.) The corollary is that hardest part of fixing a mechanical problem is determining what needs to be fixed. I find that I have a fair ability to fix mechanical problems, but unfortunately a mediocre ability to determine what problem requires fixing. Thankfully this forum provides valuable assistance in diagnosing problems.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
    Quote Originally Posted by akbeemer View Post
    On several occasions I have opined that electrical problems are usually the easiest problems to fix. And on an equal number of occasions I have been challenged and derided for that opinion. Until I explain that they are almost always easy to fix but range from difficult to impossible to find. Happy New Year.
    CAL0987
    Oct 2010
    Pahrump NV
    Yes, when I serviced the carbs, i did adjust the float level by bending the levers on te floats...
    I just regret having to take the carbs apart again!!
    CAL0987
    Oct 2010
    Pahrump NV
    Finally getting around to working on the bike again!
    Mostly from the fear of having to get out the carbs again!
    Just got my thumb screwdriver in, so adjusted the idle mix screw form 3 turns to 4... seemed to change the acceleration form blah with the choke off and good with the choke on, to good with the the choke off and great with the choke on.
    With the choke off I get hesitancy accelerating, and with the choke on, i get no hesitancy, great acceleration.
    Next step is to try 4 1/2 Turns of the idle mix screw?
    CAL0987
    Oct 2010
    Pahrump NV
    Rode it some more with the screws at 4 turns...seemed to be better when I got the cobwebs out and properly warmed up. But seemed to still get better acceleration when the choke was on.
    Jul 2018
    Corralitos, CA - Santa Cruz County
    I took the inline filter off my '97 as its not needed IMO. I finally did that after a buddy from the Harley world told me some gravity systems are very sensitive to flow. My bike performed better when I removed the filter. There are two screens before the carb, one in the tank and then one inline before the carb. Never had an issue.
    Also there were issues with some older carbs getting tears in the vacuum membrane at the top of the carbs which will definitely affect performance. You can inspect and replace those with using a right angle phillips head without removing the tank but its tight.
    Signature
    CAL0987
    Oct 2010
    Pahrump NV
    Looks like there is a possibility that some bad gas might not have been helping... after a recent fill up it seems to be preforming better...
    CAL0987
    Oct 2010
    Pahrump NV
    Nope...with the return of a few days in the 50's and 60's... just does not like the cold weather!!!
  1. Replies: 11
    Last Post: 12-01-2011, 02:23 PM
  2. Acceleration!!!
    By 98lee in forum Campfire
    Last Post: 09-01-2009, 05:40 PM
  3. What is acceleration?
    By PAULBACH in forum Campfire
    Last Post: 06-24-2008, 11:13 PM
  4. Valve Adjust - How cold is cold enough?
    By PacWestGS in forum Oilheads
    Last Post: 10-26-2006, 11:21 PM
  5. Help! K75 has no acceleration
    By SweetT in forum Flying Brick K-bikes
    Last Post: 07-07-2004, 12:43 AM
