Results 1 to 4 of 4
Thread: F-Twins Tech F650/700/800 - Engine Oil Level Check
    Jun 2009
    Rochester, MN
    The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
    The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
    It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
    Lastly, please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability. Here's a link where you can look up a place to dispose of your used fluids (oil, coolant, brake fluid, etc.) - http://earth911.com/
    This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
    Besides tires, there is nothing more hotly debated on various motorcycle forums than engine oil. Personally, I ascribe to this thinking: "Having engine oil is better than having no engine oil. Having engine oil at the correct level is better than having engine oil that is too low or too high. Having the correct viscosity/rating is better than the incorrect viscosity/rating. Finally - Having clean oil is better than having dirty oil."
    Though it seems easy, BMW recommends a specific procedure for all twin-cylinder F650, F700 and F800 bikes and models.
    Tools Required:
    - Paper towel, rags, or your least-favorite t-shirt
    Before checking your oil level, warm up your bike to operating temperature by riding, or letting the bike idle until the cooling fan comes on. Then place the bike on the center stand or have a friend hold the bike upright.
    Jun 2009
    Rochester, MN
    Clean off any foreign material by the dipstick, as we don't want any dirt to fall into the oil.
    Note: the dipstick is located on the clutch-side of the bike
    Unscrew the dipstick and clean it off with your rag, then place the dipstick back into the hole without screwing it in
    Jun 2009
    Rochester, MN
    Finally, pull the dipstick back out of the hole - making sure that the oil level is between MIN and MAX.
    The oil level on this particular bike is at about 80% full.
    If the oil level is too low: add oil, noting that the difference between MIN and MAX is approximately 1 quart.
    If the oil level is too high: I recommend unscrewing the oil filter, dumping out the small amount of oil contained in the filter, and then reinstalling the oil filter with proper torque.
    Jun 2009
    Rochester, MN
    As a point of reference, here's what a completely clean dipstick looks like.
  1. F-Twins Tech F650/700/800 - Renewing Brake Fluid
    By drneo66 in forum F-Twins DIY/Tech Library
    Last Post: 02-24-2021, 11:36 PM
  2. F-Twins Tech F650/700/800 - Battery Removal
    Last Post: 01-17-2021, 03:16 PM
  3. F-Twins Tech - F650/700/800 - Air Filter Replacement
    Last Post: 01-17-2021, 02:06 PM
  4. F-Twins Tech F650/700/800 - Engine Oil Change with Filter
    Last Post: 12-04-2020, 12:59 PM
