Results 1 to 9 of 9
Thread: K1300GT has covid?? (mystery start fail)
    K1300GT has covid?? (mystery start fail) (SOLVED!)
    Hi all! I'm new to MOA (just joined earlier this year after buying my barely-used 2010 K1300GT back in Nov 2017), and first tried to use the many Search functions before posting my newbie-needs-help thread on what I'm hoping ends up me saying "duh!"
    I last rode the bike in spring a few times... new battery installed back then... loaded with gas... but it sat over the summer with no riding and no starting. I'm in northern NJ and figured I'd better take advantage of these last few sunny/warm days to get a few rides in before winterizing.
    Rolled it out of the heated garage after removing tender, turned key on... heard whining of the fuel pump... pushed started button... engine is healthfully cranking and turning... all lights are normal on the dash... but it doesn't start. Did that for 6-7 attempts and then rolled it back in.
    Repeated the same exercise the next day with same result.
    Hmm. Weird, imo. All seems fine with the bike. But am I missing something simple? Yes, it's in neutral... plenty of charge (again, new battery in spring, sitting on tender in heated garage year-round, etc).
    Any thoughts, wisdom and advice will be appreciated. THANKS!
    Glenn
    gig harborr ,wa
    Kill switch maybe?
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by EUGENE View Post
    Kill switch maybe?
    Start and stop is the same rocker switch on a K1300.
    Lee
    2016 R1200RS
    MOA # 30878
    Apr 2006
    Nibley, UT USA
    Possibly a sidestand or neutral switch stuck or malfunctioning? If the bike is recognizing neutral the SS switch shouldn’t matter, but worth a test anyway.
    With the bike on the centerstand, make sure the neutral light is coming on with the ignition switch—try shifting into gear, then back to neutral. Then unfold/fold the sidestand a few times before folding it up. Then try starting the bike and report back.
    Best,
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT — 2018 R1200GS
    Registered User kychris02's Avatar
    Jul 2006
    Northern KY
    Quote Originally Posted by GTRider View Post
    Best,
    DeVern
    +1 on GTRider... try it in neutral with the sidestand up. That exhausts my mechanical prowess..
    Aug 2018
    Fargo, ND
    Would the fuel pump run if it was a side stand safety switch? I want to say no.
    Just because the fuel pump runs doesn't mean it is pumping or getting fuel. Check for spark, if you have spark I would pull the air cleaner a give it a shot of gas then crank it again. If it fires obviously a fuel problem.
    From the only real Fargo, ND!
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by PoorUB View Post
    Probably not, but the fuel pump is so buried on these bikes I can never tell if it’s running or not—probably just my bad hearing at play. IIRC, on a normal start the pump will initialize just long enough to pressurize the fuel rail, then shut down until the starter is engaged. The original post states the bike won’t start but doesn’t indicate if it is attempting to fire at all.
    Unfortunately, getting access to a spark lead on these bikes requires removal of the body panels and draining/dropping the radiator. The coil caps on individual plugs have been known to fail occasionally, especially if mishandled during service, but the bike would still fire on the other plugs unless something is telling the ECU not to fire the plugs. Accessing the air filter requires removal of only the RH body panel but leaves no direct access to the throttle bodies so it might be tough to get a squirt of gas down the throat. A SMALL shot of starting fluid into the air chamber might show whether there is spark. I hate using that stuff, tho, because it’s dangerous and if misused can make a large problem out of a small one.
    The OP hasn’t checked back in; perhaps his was a fleeting anomaly and he’s out riding...
    Best,
    DeVern
    DGerber
    SOLVED! (thx for feedback!)
    Best,
    DeVern
    BINGO! Threw her up on center stand, key in/on, kickstand up, put in first gear, clutch in, start button, turned right over in a hot second.
    Then for good measure I shut her down, put back on kickstand and repeated the process... but in neutral on the kickstand... started right up again.
    Gremlins, no doubt.
    Thanks GTRider... and all!
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by brbnhuntr View Post
    Gremlins, no doubt.
    Actually, that behavior is by design—to keep the bike from being started in gear with SS down and have the rider get underway without retracting the SS.
    Enjoy the ride, the K13GT bikes are great!
    DeVern
    DGerber
  1. Riding Motorcycles During the COVID-19 Pandemic
    By moshe_levy in forum Just Ridin'
    Last Post: 05-21-2020, 06:35 PM
  2. Riding Motorcycles During the COVID-19 Pandemic Part II
    Last Post: 04-10-2020, 12:13 AM
  3. Hit a Giant Pothole!!!! ABS Fail and Cruise Control Fail...
    By prtzboss in forum Hexheads/Camheads
    Last Post: 06-12-2015, 11:11 PM
  4. Batterytender fail.
    By dorongrudo in forum Gear
    Last Post: 03-14-2009, 06:32 PM
  5. Batterytender fail.
    Last Post: 02-27-2009, 09:31 PM
