Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: No spark
    May 2018
    Thousand Oaks, Ca.
    No spark
    Hello Oilhead Hive Mind,
    I did a search but I think I'm doing something wrong because when i search "no spark" i get posts from every forum and I don't see No Spark in any of the collected threads.
    That aside, I hope I can get a check list /work flow for discovering the no spark issue.
    2002 R1150Rt 17k miles. Was running 8 months ago, quit. Wouldn't start again, they sold it to me. The bike is just spotless.
    Sidestand up, clutch pulled in, kill switch in center position, crank but no spark.
    Is there a way to test the Motronic, HES and coil? I assume it's on of those. Though from what I did read, they were not common fail issues on the 1150Rt. The side stand and clutch switches could be a problem I know, how would I test for those?
    Please point me in the right direction or to the posting where this has been discussed. I'm dying to try this bike out. Thank you!
    Markus
    2000 R1100RT 118k mi
    2001 R1100RT 35k
    2002 R1150GS 80k
    2002 R1150RT 17k
    Liaison 20774's Avatar
    Markus -
    Generally the forum software search function is pretty poor. Your search found all threads with the word "no" and/or "spark" in them. So no wonder it was confusing!
    While waiting for the experts, try this. Go to google and type in the search box site:forums.bmwmoa.org "no spark" ...include the quotes around no spark to find where these two words occur together. There might be some further reading there.
    Step 1 would be to determine if it has just lost spark or whether it has also lost squirt. You can do this by removing one of the injectors but leaving the plumbing and wiring connected. Aiming the injector into a suitable container, crank the engine and observe the spray pattern. A nice spray is good. Dribbles are bad.
    Your 2002 1150 is probably early enough that it was built with the early HES wiring which always fails. If the HES wiring fails you will lose both squirt and spark, or might get very erratic bits of both.
    Do this test and let us know what you find.
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    I gotta second that comment after you have checked all your fuses, actually pulled them out and looked at them and pulled every relay and re-installed. Then you can confirm all your grounds are good and start looking for something more onerous.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    May 2018
    Thousand Oaks, Ca.
    Markus -
    Thank you for this! I have a new habit now.
    May 2018
    Thousand Oaks, Ca.
    Okay, so when I turn the bike on, I get a spray of fuel out of the injector, fine mist. When I crank, nothing. No fuel mist. Twist throttle, still no mist. This means HES is bad?
    Mansfield,MA
    How old is the battery?
    Mod Squad
    2009 F800GS 1994 TW200
    May 2018
    Thousand Oaks, Ca.
    Brand new.
    Quote Originally Posted by mykrs View Post
    It is a very strong indication that the HES wiring bundle is bad. I recommend you PM GSAddict who can provide good advice and he does rewire these HES.
    Mansfield,MA
    Brand new.
    Great. Down on the lower left you can search HES in the Tag Cloud.
    Mod Squad
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Thank you Paul.
    Considering the low mileage (17k) I am doubtful that the wiring is bad enough yet to cause the issue.
    That being said, although rare, is could be a faulty upper sensor. (which is replaceable)
    I would be glad to test the unit on my rotating tester and do a heat test on both sensors.
    Either way the wiring should be upgraded as it will fail at a later mileage.
    Reto
    Ufda happens..........
    May 2018
    Thousand Oaks, Ca.
    MORE help Needed!
    The hall sensor did the trick and there is spark!
    Now...
    There was no fuel, so I replaced the fuel pump, filter and hoses. The small hoses in the tank were shot, so I thought that was my problem, fixed.
    Still wouldn't start, would chug a bit but wouldn't run.
    I adjusted the valves, intakes were good. Exhaust were too tight. Both sides.
    Checked fuel injectors, left side no action, right side some action. So I replaced the fuel injectors with used, but working, fuel injectors and both sides spit fuel, so installed them, and gave it a crank...
    STILL won't start. It allllllmost starts, it sounds like it's gonna start, that cough of ignition, and sorta runs for just a second, but won't just catch and run.
    What's left? What have I missed?
    To remind you; This is a 2002 r1150rt with 17k miles that I bought not running from a guy who said it was idling, stopped and wouldn't start again, and it sat then for 8-10 months before he sold it.
    All ideas are welcomed...it's got me beat right now. Thank you!
    Markus
    2002 GS
    2000 RT
    1999 Funduro
    2001 RT
    Mar 2013
    Go back to the beginning. Smarter folks know that you go back to the start and carry-on forward.
    Pull, push, bang and blow.
    If you are missing one or they aren't at the right time, it won't run.
    If you got spark, fuel to the injectors, a compression test, properly done, might reveal a few things.
    Feb 2008
    Have you done a compression test?
    Both plugs out, throttle held open.
    Report back.
    May 2018
    Thousand Oaks, Ca.
    Well I did do a compression test, though I did not have both plugs out, I did hold the throttle open and I got 70 pounds per cylinder. If I took the other plug out and sprayed the cylinder with some oil would they go up to 90-100? Would both plugs being out make a big difference? Is 70 pounds really bad news?
  1. Spark plugs (again) - Dual Spark R1100s
    By BC1100S in forum Oilheads
    Last Post: 09-25-2015, 06:43 PM
  2. dual spark or single spark?
    By plexiform in forum Oilheads
    Last Post: 03-27-2013, 12:15 AM
  3. How Fat Is Your Spark
    By hoffmanswen in forum Oilheads
    Last Post: 05-21-2010, 03:50 PM
  4. No spark
    By MarkCBouchard in forum Airheads
    Last Post: 08-09-2008, 07:06 PM
  5. No spark on an R60
    By kbasa in forum Vintage
    Last Post: 08-07-2007, 05:08 AM
