91 k75s Fork Lock Question
I don't know if anyone has had this quirky problem. I put the key into the fork lock with the forks turned all the way to the right. The lock moves slightly inward, likes it's loose, but then just stops. I can't feel any detent or anything that suggests there is a place for the lock to go into. I swing the fork back and forth, but again, nothing. I don't know how anyone could break a fork lock, but maybe it's possible. I'm using the ignition key that came with it, the old folding style, and I have another flat key. Both go into the lock but won't turn it, or push it it any further. Did someone change the ignition lock and throw away the original key set? Good chance. Is it possible to get the original fork lock key? Any advice? Thanks.
The fork should lock with the front wheel turned to the left, so give the lock a good soaking with TriFlow or a similar lubricant then try it with the wheel turned left.
Best,
DeVern
Sorry DeVern. It's different on a K75.
Turn wheel all the way to the right and insert key into fork lock.
Turn key to the left (counter clockwise) and apply inward pressure. Hold the key in that position with inward pressure.
Slowly turn steering towards center. When you get about half way towards straight, you will feel the key go in about 3/16". Turn key to the right and remove key.
:dance:dance:dance
I stand corrected; thank you Lee! :thumb
That’s completely opposite from my liter/liter+ brick-k bikes as well as any other motorcycle I’ve ever owned- back in the day the conventional wisdom was that parking with the wheel cranked left added stability and made it tougher for the bike to be accidentally bumped off the sidestand. Unless the sidestand was on the right, of course...
Best,
DeVern
I tried to get to to move in but no luck. The fork moves smoothly back and forth with no hint of where the detent is. I assume that there is some part of the lock that actually slides in the lock barrel. The lock probably hasn't been used in a long time. Although the part I can see is moving around, maybe the other part is frozen in place. The only thing I can think of is to patiently shoot Kroil onto the lock for a few weeks to see if that helps.
Would it be okay to gently tap on the face of the lock with a small plastic bar, (without the key in),
or could that damage the lock?
John,
The lock cylinder only moves in when the key is turned all the way to the left AND the slot in the steering shaft is aligned with the lock. Randomly tapping on the lock will likely not have positive results since you can not meet the above requirements with the key out.
Do you have the bike on the center stand?
Are you holding the key fully to the left and holding inward pressure on it as you slowly turn the steering from the far right towards the center? Do you feel the lock move inward about 1/8" to 3/16" at about the steerings half way point between full right and straight ahead ?
:dance:dance:dance
Are you turning the key to the LEFT? It should turn to the left about 45degrees (1/8 rotation).
You need to maintain inward pressure on the key. You might not feel the lock cylinder go in when you reach the slot in the steering head, but the steering will hit a stop when the lock cylinder goes into the slot. Keep the steering pressure against the stop while turning the key back to the right. Remove key.
:dance:dance:dance
I gathered from the original post that neither of the bike keys would turn. If that is so then it won't lock. Some penetrating lubricant sprayed in the lock might help. Or maybe neither key actually fits that lock.
I discovered early in my ownership of my K100 that the fork lock was so difficult to engage that I had a concern that finally locking it might be difficult (impossible?) to unlock.:banghead So far, in almost a hundred thousand miles, no one has disappeared with the old K.😊
Yes, you CAN break the fork lock. 100 years ago I locked my brand new K100RS with the folding key and could not get it to unlock. Since I didn't want to leave my new bike at a burger joint and walk home (this is well before cell phones) I broke the lock pin by jamming the fork to the right until it gave way. I got it fixed and was told by the tech to NOT use the folding key on the fork lock since it has closer clearance than a flat key. 35 years later and I have never used the fork lock again no matter the key.
Frank
True, neither key, (folding or flat) wants to turn the lock. I can see that the lock is loose in the barrel. I am left with the conclusion that Paul is correct; these keys aren't the ones that came with the bike and won't work. The folding one works the ignition, so maybe it was replaced. Is there a way to get the right key for it, using the serial number and BMW's records? I don't see any numbers on the fork or seat lock.
I'm probably going to follow other's good advice and skip ever using the fork lock. But it would be nice to at least have the correct keys. Another lesson learned (again): never buy a bike that hasn't been well cared for.
John,
As DeVern has suggested, try squirting copious amounts of TriFlow, WD40, or Kroil into the key slot. Then run the key in and out many, many times. Then see if it will turn 1/8 of a turn to the left. If not, repeat a few times. You might get lucky and only have stuck pins in the lock.
The brass drive rivit is what holds the lock in. If you can grip it with some end cutters or side cutters and pull it out (twisting counterclockwise I think and pulling), the lock is rekeyable to your existing ignition key. If you are really careful, you might not trash the rivit and be able to reuse it. Finding the appropriate size rivit to replace it might not be easy (I don't know).
:dance:dance:dance
My '90 K75s has the same issue, lock barley turns at all and does not lock. No movement in or out. Mine is very much original at two owners and 12K miles. Both the ignition key and the side case keys fit in. (ignition is the folding key) As the ignition key is the one that works with the seat/helmet lock I am assuming it would also be the one for the fork lock. Will try some penetrating oil and see if it helps, but I really don't use it anyway. I am just rather anal and like everything working as it should.
