jconway607
JohnWC
I don't know if anyone has had this quirky problem. I put the key into the fork lock with the forks turned all the way to the right. The lock moves slightly inward, likes it's loose, but then just stops. I can't feel any detent or anything that suggests there is a place for the lock to go into. I swing the fork back and forth, but again, nothing. I don't know how anyone could break a fork lock, but maybe it's possible. I'm using the ignition key that came with it, the old folding style, and I have another flat key. Both go into the lock but won't turn it, or push it it any further. Did someone change the ignition lock and throw away the original key set? Good chance. Is it possible to get the original fork lock key? Any advice? Thanks.
