Results 1 to 9 of 9
Thread: Likely a long shot....need heated seat connector
    Jul 2018
    Bryan TX
    Cool Likely a long shot....need heated seat connector
    Looking for the driver seat connector. If I'm correct....BMW does not offer that part probably since it is part of the heat pad. If someone has a heated seat that no longer works perhaps cut the connector off and I could splice it. The harness for the bike side can be bought so I'm good there unless that's also available. Thought I'd ask.....want to get that wiring back to OEM. Thanks so much!
    '07 RT in Silver
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Send me a PM. I might be able to help you.
    Ufda happens..........
    Repair Plugs
    If you look at the Classic Parts Fiche site at one of the bigger dealer sites you can find replacement connectors that are not too unreasonable. I just bought a connector in order to wire an aftermarket set of horns. It helped me avoid cutting into any of the factor wiring. This is the link to the MaxBMW site, but others have them as well.
    https://shop.maxbmw.com/fiche/Diagra...6&rnd=09082020
    good luck
    This part will work
    83 30 0 402 344
    https://shop.maxbmw.com/fiche/PartsS...ts=83300402344
    Jul 2018
    Bryan TX
    Appreciate the tips everyone. Should be able to figure something out that will work for me
    '07 RT in Silver
    Roger...check your email...call me.
    Gregg
    Jul 2018
    Bryan TX
    Connectors found. Thanks rangemaster
    '07 RT in Silver
    Registered User AjaxTheDog's Avatar
    Jun 2013
    Highlands Ranch, CO
    An alternative
    Buy one of these, remove the pins from the old connector and reinstall in the connector of your choice that uses the same pins. Say goodbye to BMW's proprietary connector plugs at ripoff prices.
    Bill in Highlands Ranch, Colorado
    2017 R1200RT
    2007 Eton Beemer Scooter
    The seat connectors are made by Tyco...and on the OPís bike the previous owner had cut off and discarded both the seat and bike-side connectors to wire another heated seat.
    I did some research and pointed him to this:
    CNKF 5 Sets AMP/Tyco sensor 2 way male female auto plug waterproof connectors for BWM Porsche benz 968405-1 7-967570-3
    by Kaifa elec
    Learn more: https://www.amazon.com/dp/B07F8MT6NL...ing=UTF8&psc=1
    5 sets for $21 delivered isnít bad, and they are also used elsewhere on the bike so youíll have spares.
  1. '08 RT - heated seat connector? (seat end)
    By W7lej1 in forum Hexheads/Camheads
    Last Post: 02-25-2018, 01:49 AM
  2. Replies: 11
    Last Post: 05-19-2017, 03:46 AM
  3. heated seat connector part no?
    By rpmiller in forum Hexheads/Camheads
    Last Post: 10-14-2008, 06:10 PM
  4. Heated Russell Day-Long seat
    By Harrington in forum Gear
    Last Post: 12-31-2006, 03:28 AM
