Results 1 to 3 of 3
Thread: re-build drive shaft on 2015 R T
    Does anyone know if someone is rebuilding drive shafts for my bike. The u joint end is messed up.
    Liaison 20774's Avatar
    Welcome to the forum! Possibly some ideas and/or reading is in these threads:
    https://forums.bmwmoa.org/showthread...-joint-rebuild
    https://forums.bmwmoa.org/showthread...ailure-R1200RT
    https://forums.bmwmoa.org/showthread...riveshaft-fail
    Hopefully some current owners will be by to help out.
    If some time goes by with not much visibility, then one of the moderators can move this to the Wethead forum.
    '14 R1200 GS Adv bigjohnsd's Avatar
    Oct 2018
    Black Hills, SD
    ADVRider thread on R1200LC Driveshaft issues and U-joint Failures - over 1500 entries
    My '14 Rear U-Joint developed a sticky spot on one phase at 48,000 miles, I replaced my driveshaft.
    The OEM U-Joint is "Not serviceable" however that joint is available https://www.drive-lines.com/elbe/tem...ies=ELBE%20106
    This ADVRider thread details U-Joint Replacement and shaft alignment https://advrider.com/f/threads/05-dr...#post-18086826
    There is a company in Michigan that rebuilds driveshafts for LC bikes with mixed results reported.
    Ted Porter/The Beemer Shop does not offer a driveshaft for LC bikes yet, they do offer replacement shafts for earlier models.
    The only dumb question is the unasked question!
    Team Pterodactyl - When we ride, we ride!
  1. A Guide to the Hexhead/Camhead Final Drive and Shaft Drive
    By drneo66 in forum Hexheads/Camheads
    Last Post: 02-16-2021, 11:16 PM
  2. Replies: 5
    Last Post: 07-05-2017, 09:43 PM
  3. Shaft drive vs. belt drive vs. chain drive
    By ultracyclist in forum Campfire
    Last Post: 04-27-2016, 05:12 PM
  4. Swap a K75RT for K75S Final Drive& Drive Shaft?
    By 128465 in forum Flying Brick K-bikes
    Last Post: 05-19-2012, 05:32 AM
  5. Replies: 6
    Last Post: 06-19-2011, 03:35 PM
