I used to charge the battery on my bike using the power outlet. Now, the charger doesn't recognize that there's a battery at all through the power port. No voltage showing on the outlet itself. Ditto a couple of add-on outlets the previous owner added.
All fuses look good. They are the old type with the fuse wire exposed at the top. Not sure if I should just replace them all...
Any advice would be much appreciated!
Gratefully,
*John
Gratefully,
*John
