I am on to the next phase of bringing a neglected 1983 BMW R100RS back to life. Some of you may have seen and posted on my brake and electrical question last week. Thanks for your responses. I have ordered the Master Cylinder Rebuild Kits along with other parts to keep this project moving.
I am digging deeper into the electrical issue now, trying to figure out why none of the idiot lights on the Instrument Cluster illuminate.
The lights for each gauge work, but nothing else.
I removed the Instrument Cluster and tested each of the bulbs in and out of the cluster, and all bulbs work as expected.
I have unplugged and sprayed all electrical connections with WD40 and cleaned them with a Q tip.
As expected, there was a fair amount of corrosion in each connection.
After doing this, I am getting the Oil light and the Generator light to illuminate. The Turn Signal, Neutral Light and High Beam lights are still resisting my efforts. I am waiting for delivery of another BMW Service Manual as my manual goes up to 1982, and does not have the proper wiring diagrams.
When that gets here, I can trace the wiring to see where this problem lies.
The headlight works, as does the High beam. The Turn Signals work, as does the Brake and Tail Light.
My question to the group:
Is there a Diode on the Circuit Board that could affect this? If so, where is it located? As we are al aware, just because it shows up in the wiring diagram does not mean it is in proximity of the other components. Any thoughts on what components I should look at first to resolve this?
