jhall
BMWMOA #24809
Having now ridden the new-to-me 1995 R100RT about 2100 miles, I have noted several pros and cons in comparison with twin shock R100s. First the pros: no ping; accepts regular gas; electric fuel valve shut off solenoid (good backup, in case I forget to close the manuals); the infamous exhaust valve recession problem has been fixed, tubeless tires, better front brake (same pathetic rear), larger fork tubes; though slightly de-tuned, power is still comparable with earlier, "big valve", R100s.
Cons: possible slight drop in MPG; possible circlip missing in transmission (only time will tell); even worse OEM rear shock than the OEM twin shocks were.
Sure glad to be back on an Airhead, and thankful to have gotten to experience a mono shock model. Overall, looks like they saved the best for last.
