kjschilling
Greetings,
I recently acquired from a BMW dealership in Roseville CA a 1995 R100R Mystic, 16,000 miles. I'm the 2nd owner of this California bike. The bike started fine and ran fine (fine, but not quite as smooth as I remember a past airhead I had owned; a 1982 R80 RT). The PO had done most of the basic mechanical work and the bike was checked out as good by the dealer before selling it to me,,(no complaints whatsoever regarding the dealership nor the PO).
The less than smooth engine performance was/is most noticeable at RPMs between 3,200 to just under 4,000 and the bike felt just a little anemic throughout just about all throttle settings,,,nothing atrocious just seems a bit anemic from a 1000 cc motor.
I checked the valve clearances, head bolts, timing at idle and at 3,500 RPM,,,,everything checked out good. Both carbs were fairly grimy so I thought what the heck, I'll clean them well and rebuild them, the PO, as far as I could tell had not done that task. I did a full rebuild (new jets, new gaskets, new floats, new pins, new diaphragms, new O-rings,,,,the works) of them closely following the videos on Boxer2valve and Brook's Garage youtube sites (really excellent sites, by the way). Got everything back together and balanced the carbs with a carbtune device. Balancing went fine.
The less than smooth engine performance (which by the way seems to contribute to a pretty noticeable vibration sitting on the seat and looking in the rear view mirrors) still exists in the 3200-4000 RPM range and the anemia still persists as well.
So, after that rather lengthy intro allow me to get to my question(s):
I happened to see a (facebook) post that included a copy of an email exchange between Bing technical support and a guy asking about what the proper jetting should be for a set of 64/32/357 & 358 carbs, which are the same as on my Mystic. (The bing manual calls for the following: main jet 135, needle jet 2.66, idle jet 45 and clip position #3) The Bing tech support guy responded that late model R100s with 32 MM carbs were jetted lean to conform to emissions regs and he recommended the following: main jet 145, needle jet 2.68, idle jet 48 and clip position #3. Has anyone else seen or heard of that different jetting recommendations for that series of 32 mm bings?
I'm wondering if the different jetting recommendations could help with my issue?,,,,,if not, any advice/guidance on what I might do next for the rough/somewhat anemic engine performance?
Thank you in advance for your help.
Cheers and all the best
