Results 1 to 15 of 18
Thread: 600 Mile Service Dealer WAY overfilled oil
    Jan 2020
    Philly Suburbs, PA
    I checked my engine oil today for the first after the dealer did 600-mile service (now has 1100 miles). The engine-level was WAY over. I managed to siphon 600ML to get it back to the MAX level while engine oil was warm and the motorcycle was level (don't have center stand so a friend held it center). Is there anything else I need to do? Could this overfill have caused any damage?
    I always smelled something burning and the exhaust was always a bit cloudy.
    Mansfield,MA
    Just curious, did they say how many/much oil you were charged for? I doubt there was any harm past the disappointment on the service.
    I would check your owners manual to make sure the oil check sequence is the way the oil was checked.
    Good luck.
    Mod Squad
    2009 F800GS 1994 TW200
    Quote Originally Posted by epirusgr View Post
    Is this on your F800GS?
    If so, did you possibly screw the dipstick back in when checking the oil level?
    In addition to engine being warm and bike level, the procedure is: Remove dipstick, wipe it clean, then re-insert but only rest it on top of the opening (without screwing it back in), remove and check indicated level on dipstick.
    If you merely unscrewed the dipstick and read it, or screwed it back in to check the level after wiping it, you will get an erroneous “over-filled” reading.
    Dec 2007
    Indiana
    A "new" (with 600 mile) - first service just done? When was last year for 800, 2018? If that's the case hope brake fluid has been changed too...and not over filled.
    '17 RT
    MOA #46783
    Jan 2020
    Philly Suburbs, PA
    Thank you all. I have always serviced my own oil and brake fluid. This time i figured i would do the first service at the dealer (i bought a 2017 leftover... got a great deal with only 34 miles when i bought it) I had them change brake fluid when i bought the bike, but clearly when i went in for the 600 Mile service they topped it off with a different fluid which contaminated the brake fluid (cloudy substance) and had to go back for a brake flush. (service tech refused to awknowledge any wrong doing)
    Now i find out they overfilled my engine oil by 600ML.
    Here are the steps I took:
    I checked the oil by turning motorcycle on until fan went on, waited 1 min, then turned it off. Having a friend hold it straight (no centerstand) on a level garage, unscrewed and cleaned dip stick, then dipped it in and checked (repeated a few times) initially the level was about 2 inches passed max. I drained 600ML. Repeated process a few times simply puting in dipstick (without screwing in Dip Stick) finally at the max level (all the steps which manual says too)
    I am actually extremely dissapointed with the service. This is why i normally perform my own services... Maybe it was just one bad service tech.
    Dec 2007
    Indiana
    Mention of dealers name would be appropriate. We need to make each other aware of the potential weak links in our inadequate dealer network.
    '17 RT
    MOA #46783
    Quote Originally Posted by Motodan View Post
    Indeed, we need and deserve to know who is messing up.
    It’s a 2.9-3.0 liter reservoir with a filter change. But in order to get all that out, you have to tilt the bike to the right for a minute or two, then put it back over on the sidestand and let it drain out some more. You get a fair bit of extra oil out by doing this.
    Two theories:
    A) They did not change the filter due to the low miles, yet added the full 2.9L amount back in after the incomplete drain.
    B) They changed the filter, but added 4-quarts of oil in the refill. The 2.9L capacity amounts to roughly 3.1 quarts. An inexperienced tech may have been handed 4-quarts of oil for the job and dumped it all in the crankcase. If you blew 100-200 ml out the tailpipe, plus the 600ml you extracted, that would get you to around 4 qts.
    It seems like the most common screw ups with service are on the basic stuff. I always look under the hood and double check work even if it’s as simple as an oil change.
    Mansfield,MA
    Condemning a dealership on one report seems kinda harsh.
    It could have been a mistake by a Master Mechanic.
    It could be the offender doesnít even work there anymore.
    ďThe only people that never make a mistake are the people that donít do anythingĒ.
    Mod Squad
    Dec 2007
    Indiana
    Get your point, but knowledge is not a bad thing...allows for more consideration, inquiry and hopefully, better decision making.
    '17 RT
    MOA #46783
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Let the shop owner and service manager know what happened.
    Lee
    2016 R1200RS
    MOA # 30878
    Jan 2020
    Philly Suburbs, PA
    Thank you everyone for your advice. I did let everybody know at the dealership but it doesnít seem that it was well received. Itís a shame that itís the only dealership in the Philadelphia Suburb. I am sure Iíll be able to find other shops. Apparently one of the best BMW mechanic works nearby at another shop.
    Dec 2007
    Indiana
    Okay, I'll remain aware of the Philly Suburb dealership.
    '17 RT
    MOA #46783
    Apr 2006
    Nibley, UT USA
    This is a two-problem service for the OPófirst an incorrect fluid added to the brake fluid and second the overfill on engine oil. Those are both rookie errors and not the sort of thing one should be seeing from a BMW franchise; the OP needs to be looking to associate with a different dealer.
    On the brake fluid error- if the mistake was in mixing mineral oil (used in the hydraulic clutch system) with brake fluid then I hope a very thorough flush of the entire system was performed. The two fluids rely on different materials for seals and cross-contamination could result in a seal failure.
    Best,
    DeVern
    DGerber
    1983 R80ST ó 1984 R80 G/S-PD ó 2004 K1200GT w/Hannigan S/C ó 2010 K1300GT ó 2018 R1200GS
    Apr 2015
    Southwestern Connecticut
    Donít know where in Philly suburbs youíre located, but you should consider Tom Cutterís shop:
    http://www.rubberchickenracinggarage.com/service.html
    2002 R1150R
    2016 BMW F700GS
  1. Replies: 37
    Last Post: 06-07-2020, 08:14 PM
  2. 18,000 mile service
    By captainmarko in forum Wetheads
    Last Post: 04-24-2018, 01:28 AM
  3. 24,000 mile service
    By bmw4life in forum Hexheads/Camheads
    Last Post: 05-21-2017, 06:18 PM
  4. 600 mile service
    By t6pilot in forum Scooters
    Last Post: 12-28-2012, 07:01 PM
  5. 600 mile service
    By iaicardi in forum Thumpers - F & G bikes
    Last Post: 07-10-2007, 04:36 PM
