AntonLargiader
Active member
I have a customer with an ST, no centerstand (looks like it had one in the past), wanted me to add one at the next service. Ordered the stand and the mounting kit, and the bushings don't match the stand. The holes in the centerstand are 20mm while the bushings are 18mm. I can understand a bit of clearance but 2mm is a rattle-fit.
I'm going to solve this with K75 bushings, but I am just curious about the mismatch. For those of you with STs, can you tell me if the holes and bushings are 18mm, 20mm, or mixed like I am seeing?
