I'm about to replace the transmission on my '99 R1100R (broke the right subframe mount on a trail ride a few weeks ago - I did order the GS hard parts kit to reinforce the mount) and I have a couple of questions before I tear into it. First off, I was planning on replacing the clutch friction disc while I'm in there. The bike has about 50k on it so I was wondering if there is any compelling reason to replace the whole clutch assembly instead of just the friction disc (the assembly is quite spendy). The trans I'm installing is a used unit from the same year and model with 30k on it according to the seller. I already have it - it's immaculate and the input splines are in like new condition - anything else I should inspect or pay attention to (without cracking the case open)?
Second unrelated question - the bike already had the canisterectomy when I bought it. Currently the vent lines are routed down the right side along the frame and tucked above the swingarm on the right side, but I've noticed that when full of fuel and especially on hot days I get some fuel dripping down on the swingarm and it's starting to discolor the paint. I don't really see anywhere else to aim it that it couldn't drip on the hot exhaust, just wondering what others have done with the vent lines - I assume I don't want to plug them.
Thanks!
Thanks!
