Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 82
Thread: Newbie Saying Hello
  1. #16
    Hi! It's been slow going, waiting for powder coaters, waiting for painters (tank and fender). But just in time for the long weekend, I've got all parts back in now and I can start assembly! I decided to try to paint the motor myself (new to auto-paint), using Duplicolor engine paint. Its been a learning experience and I'm mostly happy with the results. The garage isn't heated though, so I had to make a temperature-controlled drying/curing box. Here are a few photo updates, most are self-explanatory... but the tail-light photo was an early prototype of the 3D-printed LED tail-light mount. While I was at it, I 3D printed a holder for some of my larger metric sockets
  2. #17
    Jul 2018
    Northern VA
    Wow. You move quick on your project!
    Looking forward to seeing how it turns out.
  3. #18
    Got a LOT done today! Loving the long weekend!
  4. #19
    slave to gravity skibum69's Avatar
    Dec 2016
    New Melbourne, NL
    I agree about the 640A, I think it's still my favourite bike. Let us know how your engine paint works out, gives me an idea for a fix I plan to do down the road.
    http://beerthief.ca
    ITSteve: ride in peace my friend
    save $5 on a new SmugMug account, use this coupon 7frrnSRiTt9Fk
  5. #20
    Jul 2018
    Northern VA
    What kind of prep did you do on the painted engine, especially since you didn't take it all the way apart.
    Also, roughly how much does it cost to powder coat the frame?
    2004 R1150R Rockster | 1981 R100 | 2019 KLX250 | 1980 R65 (sold)
  6. #21
    Quote Originally Posted by R65_Steve View Post
    The engine is still in process... for all the other parts that I did, I took them down to bare metal, mostly using Nyalox brushes, which are nylon brushes infused with an abrasive. I then cleaned with isopropanol, followed by a second clean with duplicolor prep spray, using blue paper towel, till no dirt was present anymore. Many hours spent on prep!!!! Then three coats of each "color": primer, black and then clear, per the instructions on the can, which call for two light coats, followed by a heavy coat, all with a 10 minute dry between coats. The engine I decided to try a bit differently as I was not too happy with the masking results I had on the cam covers. With those, I masked off the fins, and went through the primer and black, then de-masked and did the clear. I was not happy with the masking lines... I wanted to try something different on the engine - (paint, dry , sand paint off the fins and then clear coat afterwards). I asked Duplicolor, and they actually replied. They said it was fine to clear coat afterwards, but wait the full 7 days that is needed for the paint to cure. I actually sanded them down today and will do the final clear coats tomorrow!
    I had the frame, swingarm, fork legs, fork clamps, center-stand and a hand full of smaller parts done for $400.
  7. #22
    Jul 2018
    Northern VA
    Quote Originally Posted by slc666 View Post
    Are you sanding off the fins back to bare metal? And just the tips right?
    I'm excited to see this turn out.
    I was thinking of doing something similar to mine...but all black with a red powdercoated frame. The tank and fender, etc are in such nice shape, it'll either make that work easier and/or the BMW world sad.
  8. #23
    yeah, just the outward-facing edges of the fins. Sanding has left a much better looking outcome so far, lets see how well the clear coat adheres now!
    I think red would be nice! Do it!
  9. #24
    sneak peek
    not looking too bad so far
  10. #25
    Jul 2018
    Northern VA
    BTW, did you scrape off the VIN sticker when you had it powder coated?
  11. #26
    All stickers are gone now.... hope I took some photos of that :o
  12. #27
    Jul 2018
    Northern VA
    Ha! Motor looks nice!
  13. #28
    BMWMOA #24809 jhall's Avatar
    Aug 2020
    Kentucky
    Heat Disappation
    I wonder if the multilayer skin of paint is gonna inhibit heat dissipation, especially on the cooling fins? I know some radiators are painted black, but with a special kind of paint, and have read precautions not to use regular paint.
    BMWMOA #24809
  14. #29
    Quote Originally Posted by jhall View Post
    From what I have read, a few 10-100Ám of paint make no difference to the heat dissipation. For something to actually insulate the motor/fins it would need to be much thicker and ideally not solid... like a nice fur coat :P
  15. #30
    Jul 2018
    Northern VA
    How's the project coming? I wanted to follow up on something....did you use the Nyalox on the engine parts too? I need to take my head's off, so I figured I'd get the valve covers and repaint at the same time. I'm curious if that what you used on the engine bits.
  1. Newbie from KC
    By skeive in forum New Members
    Last Post: 05-10-2017, 03:22 AM
  2. Another Newbie from AZ
    By RETPD2001 in forum New Members
    Last Post: 12-02-2012, 11:07 PM
  3. Another Newbie
    By 181849 in forum New Members
    Last Post: 05-20-2012, 10:16 PM
  4. hello fom a newbie
    By mrbreeze in forum Oilheads
    Last Post: 09-23-2007, 03:13 AM
  5. newbie
    By chopperdave in forum Thumpers - F & G bikes
    Last Post: 01-24-2007, 04:32 PM
