Results 1 to 8 of 8
Thread: 2009 K1300GT - Safety Recall - 20V-471: Fuel Pump
    Sep 2019
    Indiana
    I recently received a safety recall notification from BMW which reads in part:
    ..."BMW AG has decided that a defect, which relates to motor vehicle safety, exists in certain Model year 2005-2011 BMW R1200, K1200/1300/1600, S1000RR and HP2 motorcycles. Our records indicate that you are the owner of a potentially affected motorcycle."
    ..."We are informing you of a safety recall on your motorcycle although we are not able to perform the remedy at this time. We will notify you with a follow-up letter as soon as the remedy is available."
    ..." Motorcycles which had the fuel pump repaired (but not replaced) during safety recall 13V-617 with a support ring attached to the fuel pump flange could, over time, experience a fuel leak. A fuel leak, in the presence of an ignition source, could lead to a fire."
    Reference: www.bmwmotorcycles.com/recall
    Well, I don't know if my MC had the recall 13V-617 performed, as I am not the original owner. I don't smell any fuel, so I guess I'm OK until I can have this checked out after the remedy is available.
    FYI...
    '09 K1300GT
    Mansfield,MA
    Sounds like the thread in Hex/Cam-
    https://forums.bmwmoa.org/showthread...Recall-new-one
    Mod Squad
    2009 F800GS 1994 TW200
    Calgary
    As expected, my letter arrived yesterday. Same story, no fix yet but they'll let me know when there is and don't ride it if there's fuel leaking. Not that the bike will be leaving the warm garage anyway until probably April.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2019 F850GSA
    Debbie's Servant Lee's Avatar
    SW Iowa
    My wife received the recall for the 2011 K1300S she used to own.
    I have not received the recall for the one I owned.
    Both biked had the earlier recall done where they pressed a metal sleeve over the fuel pump flange.
    Lee
    2016 R1200RS
    MOA # 30878
    Sep 2009
    Chestnut Hill, MA
    Anyone can check for a recall on the NHTSA website. Get your 17-digit VIN ready then look here: https://www.nhtsa.gov/recalls
    BMW has its own website for probably the same information: https://nhtsa.bmwgroup.com/safetyrec...llSearch.xhtml
    John Gamel - BMW MOA Consumer Liaison 2018-Present
    2015 Ebony Metallic R1200RT
    MOA #153274
    "We have met the enemy and he is us." Pogo-via Walt Kelly
    Liaison 20774's Avatar
    I've tried to keep up with the various recalls, but sometimes things slip by. I've been adding to this thread:
    https://forums.bmwmoa.org/showthread...Recall-Notices
    Sep 2009
    Chestnut Hill, MA
    Wow! Pretty impressive Kurt!
    MOA #153274
    Mansfield,MA
    All connected through the clickable link (in bold) in Kurtís signature line.
    Mod Squad
  1. Recall is on- fuel pump flange/fuel pump
    By David13 in forum Motorrad
    Last Post: 10-25-2018, 10:15 PM
  2. Fuel pump recall??
    By gene36542 in forum Hexheads/Camheads
    Last Post: 04-29-2014, 04:27 PM
  3. 2009 K1300GT water pump failure
    By TOMKNOX in forum Wedge K-bikes
    Last Post: 07-26-2010, 11:16 PM
  4. Recall: BMW K1300GT and K1300S 2009-2010
    By mika in forum Wedge K-bikes
    Last Post: 06-28-2010, 03:27 AM
  5. Fuel Pump recall
    By BMRUP in forum Oilheads
    Last Post: 04-09-2005, 12:05 AM
