Results 1 to 6 of 6
Thread: 2005 K1200S Coolant Reservoir Elimination
    I have a 2005 K1200S that recently began eliminating about half of the contents in the coolant reservoir when I turn the bike off when the auxiliary cooling fan is on. It only happens when the bike is hot and the auxiliary cooling fan is on. The coolant is being ejected out of the hose that exits behind the engine on the left side of the bike. Anyone had this problem? Thanks - David
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by dkmbmwmoa View Post
    Assuming that the coolant level haas been set correctly as per the owner’s manual, the next two items to check would be the radiator cap and the condition of the radiator itself. By that, I mean making sure the fins aren’t plugged and that the aux fan can actually move air through the radiator. The radiators on the wedge-k bikes collect a lot of crud due to their placement and some have reported corrosion issues leading to leaks. But on a 15yr-old bike a new radiator cap is the first thing I’d try.
    Best,
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT — 2018 R1200GS
    Left Coast Rider
    Nov 2011
    These rad caps are kind of pricey - $43.00. Is there an OEM replacement available?
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by BC1100S View Post
    I’ve not found one. I note that BMW lists two different part number caps for the K1200S. One is flagged as “1.8 bar” and the other bears no value. It might be advantageous to visit with your dealer’s parts or service department to see which is recommended, in case the difference is relative to your problem. From Bob’s BMW parts fiche:
    06 17 11 7687715 Cover lid 1.8BAR 1 $43.03
    06 17 11 7695413 Cover lid 1 $34.44
    Best,
    DeVern
    DGerber
    Thank you!
    Thanks DeVern. I will follow up with my shop on this. - David
    Apr 2006
    Nibley, UT USA
    DGerber
  1. 2003 K1200GT, Oil in Coolant reservoir
    By bruceweg in forum Flying Brick K-bikes
    Last Post: 09-15-2017, 10:09 AM
  2. '87 K75s / Oil in Coolant Reservoir
    By kentuvman in forum Flying Brick K-bikes
    Last Post: 07-20-2012, 09:54 PM
  3. coolant reservoir weirdness
    By jobee58 in forum Flying Brick K-bikes
    Last Post: 01-21-2009, 05:04 PM
  4. K1200S/R/RS coolant replacement
    By john1691 in forum Flying Brick K-bikes
    Last Post: 06-23-2008, 07:27 PM
  5. 91 K100LT Coolant Reservoir Leak
    By warthog in forum Flying Brick K-bikes
    Last Post: 01-08-2006, 06:56 PM
