rangemaster
Those of us with hexhead bikes remember the “fuel flange “recall from a few years back.
The original problem was the composite flange at the quick disconnect coming out of the fuel pump assembly was flexing due to pressurization and depressurization of the system and developing cracks around the base. The fix in that last recall was to place a metal retainer clamp/ring flange over the plastic flange to reinforce it and to eliminate or mitigate any cracks.
Well apparently that fix wasn’t good enough; in the mail today from BMW I got a recall letter saying if you had that recall done, they want to replace the fuel pump. Apparently there have been more reports of leaks and that metal flange didn’t solve the problem.
Also of note is the line “no remedy available yet “ - which means to me that they either have to put a different style fuel pump assembly in - or they are building up enough parts up to send out to the dealers.
I will post a copy of the letter when I get home. It affects a number of bikes...not just 05-09 RTs...
I had that recall done on my last R1200RT, I can’t recall if it’s been done on this one. I’m going to pop the side panels off and inspect it. Either way, if it’s not leaking now I won’t quit riding it, just wait for the fix and inspect at regular intervals.
I expect I’m good for right now, because I haven’t smelled gasoline at any time while the bike is running.
