Results 1 to 6 of 6
Thread: Extra Hose After Carb Service
    CAL0987
    Oct 2010
    Pahrump NV
    Smile Hose diagram,airbox/carbs/gas tank
    Trying my hand at working on a 1998 F650 this time!
    Took a while to take the bike apart to get to the carbs. Did some replacement parts on the carbs and again a while to get it back together.
    After assembly, it seems i have an extra drain hose unaccounted for....
    SPent a long time online trying to find a good hose routing diagram for the carb and Airbox, but not much out there.
    So I made my own, I hope I reconnected everything correctly, was a little sloppy taking it apart.
    Not sure where the extra drain hose attaches to, it is on the left side , under the battery tray.
    Also more fun: discovered after assembling everything, that when i went to connect the fuel line to the Petcock, it was about 2" short.
    The hose must have bee run from the carb facing the engine, and i ran it back way from the engine and around the fram.
    Rather than taking everything out again , decided to add some more hose to bridge the gap... seems the easiest way
    Sep 2006
    CENTEX USA
    Is the hose the battery vent from original flooded battery?
    There are a lot of abandoned battery vent lines since AGM’s were introduced on older bikes
    Steve Henson-Mod Team and past prez SABMWRA
    CAL0987
    Oct 2010
    Pahrump NV
    Sounds like a great idea! I was kinda thinking the same, as the hose has some white residue inside...
    Registered User Guenther's Avatar
    Jan 2007
    Colorado Springs, CO
    From the picture it looks like the hose with the ??? is connected to the air box or is this a guess?
    /Guenther
    2017 F700GS - I wish she had a drive shaft
    CAL0987
    Oct 2010
    Pahrump NV
    Quote Originally Posted by Guenther View Post
    /Guenther
    No, that is just the extra hose connected to nothing.... Yesterday I removed it, assuming it was for the old battery box
    CAL0987
    Oct 2010
    Pahrump NV
    Originally Started as a project to get my Girlfriends 1997 F650 back and running after it was "puking petrol" 2 years back and had sat in the garage since. So took apart the carbs and replace most, except the floats , as they seemed good.
    I think it was a case of leaving the Petcock open too many times and for too long! Some of the seals may have been old too, but it was hard to tell since it sat so long. Did some float height adjustment also.
    Got everything back together after much struggling... went to connect the fuel line, and ooops, 2" short..damn! Turns out that I had run the fuel line back and around the frame, which I thought was the way it had gone, instead of forward close to the engine. Well instead of taking everything apart again, I just added a fuel filter and some extra fuel line on the way to the petcock...problem solved. .went to start up...nothing. turns out the battery was dead after 2 years sitting, even though I had periodically charged it. So ordered new battery, installed today, and after a little sputtering, it started! Took it around the block. .we have a running bike!
  1. What is this hose for?
    By Dann in forum Hexheads/Camheads
    Last Post: 03-22-2015, 06:47 PM
  2. Replies: 12
    Last Post: 03-13-2014, 08:29 PM
  3. Which Fuel Hose goes there?
    By lkydvl in forum Oilheads
    Last Post: 05-11-2013, 06:15 AM
  4. Carb Air Intake Hose
    By tkdan235 in forum Airheads
    Last Post: 08-24-2008, 01:03 AM
  5. Rubber hose
    By bullshit in forum Airheads
    Last Post: 01-09-2008, 02:23 AM
