Results 1 to 15 of 20
Thread: Tpms removal?
    Jul 2017
    Waco, TX
    Tpms removal?
    Will the tire still hold air if I remove the tpms from the front wheel? 2017 RT.
    Bob
    Quote Originally Posted by bobw View Post
    Bob
    Not unless it is replaced with a different valve stem.
    Mansfield,MA
    Bob
    I will add a bit of a description to the title. It will help all the way around.
    Good luck.
    Mod Squad
    2009 F800GS 1994 TW200
    Jan 2015
    Pickering, ON, Canada
    You can
    Bob
    The tpms sensor is separate from the valve stem and can be removed (with the tire removed from the wheel) and the remounted tire will still hold air.
    #1 is a mounting screw, not the valve stem.
    The rear wheel is the same. I suspect this was because BMW now has the valve stem in the spoke of the wheel, perpendicular to the angle of rotation of the wheel.
    Bob
    2014 R1200RT
    Jul 2017
    Waco, TX
    Thanks Bob_One
    What I want to do is take it off when I put a new front tire on and try and replace the battery and if successful put it back at the next tire change. And in the meantime I ordered the FOBO tpms.
    Bob
    Quote Originally Posted by bobs_one View Post
    Thanks. I stand corrected. Still, I would like a new valve stem with each tire change if it is a rubber stem. If a metal stem, maybe new O rings.
    Registered User cap's Avatar
    Oct 2016
    Fort Collins, CO
    Bob
    What is FOBO? I bought a set of clone TPMS for about $20 each on Amazon. They work fine. I checked and found that my seller doesn’t list them anymore, but there are plenty of others listed. Search for part number 36238521796 . Don’t forget that you may need to replace the “pin.” And you will need a “wake up” tool, and also a GS-911 to learn the new TPMS ID codes.
    Boxflyer did a nice video on the process.
    Registered User natrab's Avatar
    Sep 2012
    Sacramento, CA
    I've had the FOBO caps on my RT for about 4 years and they still work great. Super convenient as well since I can check my tire pressure from my living room without having to get on the bike and ride it. They do require battery changes fairly often, but it's NBD.
    Current rides: 2013 R1200RT 90th - 108k miles & 1996 R850R - 28k miles
    Previous BMWs: 2016 R1200RT, 2012 R1200GS Rallye, 2011 R1200RT-P, 2007 R1200S, 2006 R1200RT
    Nibley, UT USA
    On the bikes with the stems in the spoke, the stem is threaded into the spoke and can be replaced at a reasonable cost, in the $10-12 range. Since the only portion of the stem that is exposed is the threaded portion the cap screws onto, these stems see very little wear or damage. BMW also sells replacement cores for those stems, <$2, but I don’t see any availability for o-rings on the stems.
    Best,
    DeVern
    DGerber
    Are we there yet? tonyfr's Avatar
    Apr 2007
    SAT - LAX - LAS
    Quote Originally Posted by cap View Post
    You can also find them on eBay for about $22
    2009 K1300 GT
    1984 Kawasaki ZX750-E1 Turbo
    1990 Kawasaki ZX600R
    2005 R1200 RT - gone
    Jul 2017
    Waco, TX
    Unhappy
    Natrab The FOBO came in and really was happy with them until I rolled the bike and bent the sensor on the front wheel. Not enough clearance and it hit the disk brake. Very disappointed. My RT is 2017.
    Bob
    Registered User AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    I'm buying aftermarket sensors these days. I can buy six sensors and a scan tool for less than the cost of one sensor from BMW.
    Anton Largiader 72724
    Tech articles - YouTube
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    Tpms
    Can you tell me the name and source and cost of these aftermarket sensors
    Howard D.
    Old Rider - OK Mechanic 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    Tmps Sensors
    Great info and tanks to BoxFlyer for an excellent video on the programming. My 1250 has different sensors. Anyone seen a replacement product for them.
    David Nicholls
    Teulon Manitoba - Canada
    2015 R1200GSA-LC
    The TPMS sending units might have different part numbers, and BMW has been doing that since about 2005 when they were more common on our bikes.
    The list of bikes with interchangeable TPMS with other models or years can be found on www.realoem.com
  1. TPMS Malfunction
    By poco183 in forum Wetheads
    Last Post: 07-16-2019, 03:14 AM
  2. K1600 gtl tpms
    By vmawa6 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 03-04-2019, 07:46 PM
  3. 2015 rt tpms
    By Dsmith1200 in forum Wetheads
    Last Post: 08-31-2018, 03:22 PM
  4. Tpms recommendations?
    By tangoalpha in forum Motorrad
    Last Post: 05-16-2017, 12:16 AM
  5. TPMS sensors
    By KevinRT in forum Hexheads/Camheads
    Last Post: 08-03-2016, 01:43 AM
