hadabadachada
Hello again. Two questions.
Any have the left side cam adjuster come loose? I’ve had to tighten mine several times. After another two months, I noticed a little oil seeping again, is this normal or am I just not getting enough torque on it?
And the rocker arms.
My bike is super noisy from the heads, adjusted the valves last month, no change in noise, not that I thought there would be. I’m looking to adjust the rocker arm gap tomorrow, followed by the valves again. The power on the bike is fine I have no issues other than it being super loud clackity clacking.
I’ve found a few pages on the web that give a little run down but still not sure.
Says you loosen the 3 T45 bolts, as well as the one nut, or is there two?
Then checking the gap, you check the gap on the bottom of the rocker arm from what I’ve gathered right?
Then fiddle with tightening. You tighten the torx bolts first or the nut?
Appreciate any pointers. Have a Trip from Miami to Asheville next week. Looking to mosey out to the dragon as well as ride the blue ridge. Be nice if the bike was quieter.
