Page 3 of 3 FirstFirst 1 2 3
Results 31 to 41 of 41
Thread: 2019 R1250RT H7 Low beam bulb change
  1. #31
    Debbie's Servant Lee's Avatar
    SW Iowa
    Last week a friend with a 2020 R1250RT spent the night with us at the end of his 36 day trip.
    We changed his low beam bulb while he was here.
    He had changed the bulb at the beginning of the trip so it only lasted 35 days.
    He did it from the front looking into the headlight while I looked from the back of the fairing with a flashlight to help give directions for the little tab and the wire clip.
    I'm guessing it took at least 20 minutes.
    Lee
    2022 R1250RS
    MOA # 30878
    Past BMW Bikes: 2016 R1200RS, 2011 K1300S, 2003 K1200RS, 1991 K75S, 1987 K75T, 1984 R100RT
  2. #32
    Registered User zip50's Avatar
    May 2018
    Lincoln, MA
    R1200Rt R1250RT Headlamp replace tip
    I have had to do this a few times on my two RT's. For me it has been helpful to put a GoPro on a selfie stick and prop it in place, add a drop light shining in from above, and looking at the GoPro app on my phone I can see what I am doing. Has made the procedure more tolerable.
  3. #33
    ohbeemer ramble's Avatar
    Jun 2004
    ohio
    My next solution to this frequent chore, is to make a ventilated access cap to this bulb area, allowing some air flow around the bulb and thus extending the bulb life.
  4. #34
    Left Coast Rider
    Quote Originally Posted by ramble View Post
    Buy LED bulbs. With a life span of 30-50,000 hours its a problem solved.
  5. #35
    I have to say; the LED lighting on the front of Anja is my favorite RT upgrade. The 2022 models definitely reflect an engineering solution that reflects a design approach that is customer feedback centric. I do not miss changing out that dim bulb.
    R. Reece Mullins 2022 Sport Blue R1250RT (Anja)
    MOA # 143779
    MOA Charter Club #5 #364 #100 #1
    BMW MOA President
  6. #36
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by rangerreece View Post
    Which one did you get?
    I'm still trying to find one that won't throw an error message.
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2019 R1250RT - 2007 R1200RT (186,000 km) - IBA # 56396
  7. #37
    Left Coast Rider
    Quote Originally Posted by Dann View Post
    The ones with the small fans seem to work for me. There are many on Amazon. I'm using H7s from a company called Aolead. I think the fan draws a little extra power which avoids the dreaded yellow triangle.
  8. #38
    Dec 2013
    Laval, QC, Canada
    Daniel
  9. #39
    Registered User gordsmarsredrt's Avatar
    Nov 2019
    Kelowna, British Columbia
    H7 led
    https://www.revzilla.com/motorcycle/...conversion-kit
    RevZilla currently has a good deal on the SpeedMetal H7 LED. I'm pleased with the conversion on my '18 RT. I cut a vent in the dust cap for room and ventilation. No errors. No "light out" message on the dash.
    Gord - Current bike: 2018 R1200RT.
    Past BMWs: '77 R100S, '77 R100RS, ('75 2002)
  10. #40
    Iím referring to the OEM led lighting that came with the bike. No error code necessary. The Ď22 was a complete redesign of the front fairing.
    MOA # 143779
    BMW MOA President
  11. #41
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Gord, Dan, etc. - there's a review of the Speedmetal kit in the Gear section -
    https://forums.bmwmoa.org/showthread...ght-Conversion
    I like it; night pattern is good too.
    (Caveat - we have different headlight assemblies, reflectors, and computers monitoring the current...)
  1. Base Price 2019 BMW R1250RT
    By jamo in forum Wetheads
    Last Post: 06-10-2019, 02:00 AM
  2. Review of the 2019 R1250RT
    By bmwdean in forum Wetheads
    Last Post: 05-01-2019, 02:33 PM
  3. 2019 R1250rt?
    By T-foiler in forum Wetheads
    Last Post: 05-13-2018, 04:02 PM
  4. LED low beam or high beam bulb - with capacitors
    By jsoque in forum Hexheads/Camheads
    Last Post: 11-28-2017, 11:53 PM
  5. Low Beam Bulb Change in 10 Minutes!
    By greenwald in forum Gear
    Last Post: 09-25-2008, 02:38 PM
