Results 1 to 15 of 17
Thread: My 2004 R1200CL won't start, Fuel pump?
    Mar 2007
    Colorado Springs, CO
    Unhappy My 2004 R1200CL won't start, Fuel pump?
    The bike was running when I parked it last night, now it won't start. It turns over but that's all. Could it be the fuel pump? How can I check to see if it is the fuel pump? Any other suggestions as to why it isn't starting? Thanks,Dave,
    Quote Originally Posted by djcondie View Post
    Remove one fuel injector, leaving the pipe and wires connected. Aim it at a suitable container and crank the engine. If it squirts robustly the fuel pump is OK. If it dribbles the pump might be the problem.
    Mar 2007
    Thank you , I will try that. Dave
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Does the CL have the square white connector from the fuel plate to the main harness? (below the right rear of the tank on the RT and RS) If that's not making good contact, the bike won't start.
    Do you have all lights operational?
    Check all fuses; if the CL is wired like the RT or RS, then F5 powers the Motronic (brain) and F6 powers the fuel pump. Each is 10 amps.
    Mar 2007
    Thank you for the suggestion I will check that out. Dave
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Can you hear the fuel pump cycle for 1 second when you turn the ignition switch on?
    Ufda happens..........
    Mar 2007
    yes, I hear something when I turn the key on.
    Mar 2007
    All lights are operational and all fuses are good.
    Do what Paul said next
    Mar 2007
    That is my next project.
    Mar 2007
    After taking Paul"s suggestion, it appears that I am not getting fuel to the injector so I have ordered a new fuel pump. To be delivered next Tuesday.
    Left Coast Rider
    Before spending more money, you might want to check the fuel line hoses inside the tank. I believe they have a history of deteriorating over time resulting in the symptoms you are seeing.
    plus 1
    1999 Triumph Tiger & 1994 R1100RS
    Mar 2007
    Thanks for the idea. The fuel lines in the tank look good.
    DBLUPPR snookers's Avatar
    Jul 2010
    Niagara Wine Region
    Since it looks as if your planning on replacing the fuel pump, consider replacing the "U" shaped fuel line that is in the tank with a flexible fuel line from "euromotoelectrics"
    It's this OEM fuel line which degrades over time and will cause you grief. Many that appear too be in good shape with the naked eye have cracks in the radius of the hose which may be undetectable until pressure is exerted on it from the inside
    https://www.euromotoelectrics.com/pr...fp-hosekit.htm
    A good time to swap out the fuel filter as well
    You will most probably never have to go into your fuel tank again
    Footnote:
    When I replaced the fuel pump on our 1100RT as have others, I changed out this fuel line and moved the fuel filter outside of the fuel tank, it's not visible on the RT as the moved filter is covered by the plastic body panel. Could be different on your bike depending on where you would mount the filter
    2000 R1100RT , 2005 K1200S w/hack
    Niagara BMW Riders #298 BMWMCO #45
    "The measure of a society is how it protects its most vulnerable members."
  1. 95 R1100r won't start suspect fuel pump
    By hotrod in forum Oilheads
    Last Post: 08-10-2020, 02:39 AM
  2. fuel pump 2004 R1100S
    By sonnyb in forum Oilheads
    Last Post: 05-30-2018, 02:18 AM
  3. 86 K100 Will Not Start Seems to be the fuel pump
    By pburbine in forum Flying Brick K-bikes
    Last Post: 07-20-2014, 05:35 PM
  4. 1992 K100RS will not start- fuel pump silent
    By tooterweber in forum Flying Brick K-bikes
    Last Post: 05-04-2014, 01:13 AM
  5. Replies: 4
    Last Post: 12-09-2007, 06:50 PM
