Results 1 to 4 of 4
Thread: K1300GT Brake Pedal Mod for Lowered Footpegs
    Apr 2006
    Nibley, UT USA
    I recently installed a set of Moto Verholen brackets for lowering the footpegs on my 2010 K1300GT, sourced from Pirates Lair. Included in the kit was an aluminum piece designed to clamp around the brake pedal of a K1200S and lower the brake pedal by adding thickness to the pedal. However, no such fix was included for the K1300GT, which uses a different pedal than the K1200S. I was not comfortable with the relationship between the now-lowered footpegs and the existing brake pedal location, so started researching possible fixes by asking for photos in a thread located here. Rather than further mess up that thread, and in order to keep this post easily reachable in a search, I'm starting this new thread. Note that what I'm illustrating here is a modification to a critical safety system that should only be undertaken by a skilled machinist and mechanic and that a modification such as this is done at your own risk.
    The pedal stop for the K1300GT is on the back side of the pedal, as shown in the photo below. The stop is just a flat portion on the pedal and designed to bottom against the frame where it meets the footpeg mounting arm bolted to the frame. The red arrow in the photo below shows the section of the brake pedal that acts as the stop.
    Removing the pedal and flipping it over showed the stop to be a flat spot on the pedal, and the pedal to have ample thickness to install an adjustable stop setup without worry of pedal breakage. I determined the correct location for an adjustable stop was near the outer edge of the flat stop area, then jigged up the pedal so I could drill a 13/64" hole perpendicular to the flat stop area, all the way through the pedal. I then tapped the hole for a 6mm x 1.0 thread as shown in the photos below:
    Hole Location:
    And installed a 6mm x 1.0 bolt and locknut:
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
    Apr 2006
    Nibley, UT USA
    The finished pedal installed like this:
    So, the next step was to shorten the master cylinder stab to the correct length. NOTE: This is a part that is only available with a complete new master cylinder, so be aware of that before you begin modifying the part. I shortened the tapered end of the stab by about 2mm with a file, maintaining the rounded profile, and the threaded portion of the stab as needed. In order to make the stab short enough it was necessary to also shorten the threaded barrel of the mounting clevis, to allow the stab to thread in far enough to maintain proper free play in the brake pedal. The photos below show the parts and give a rough idea of how much length was removed:
    Note that this is a size-to-fit situation and will likely require multiple test fits along the way. It is CRUCIAL that the end of the threaded portion of the stab not be allowed to protrude below the inside surface of the clevis, as shown here, or it will interfere with free play in the system.
    And the installed stab and clevis looks like this. Note that there is a limited amount of adjustment retained, in case the pedal is adjusted upward and the stab lengthened accordingly. I wanted the pedal in the same space relationship it originally had with the footpeg, so my pedal is lowered a bit more than many would do and the stab is correspondingly shorter. Note again that it is CRUCIAL that free play be present in the system when you are done adjusting, otherwise the rear brake will drag and overheat. I verified that the rear wheel would spin free when done, and that sufficient free play was present to allow the pedal to move a bit before the brakes began to lightly engage.
    Anyway, that's my mod. I could have heated and bent the brake pedal, but I wanted to retain some adjustment. Should the day come when I need the pedal higher, if I find my stab is too short I'll just fire up the lathe and make another using a 6mm x 1.0 grade 5 or grade 8 bolt as a starting point.
    Do this mod at your own risk and on your own responsibility!
    Best,
    DeVern
    DGerber
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Very nicely done and presented!
    David Brick
    Santa Cruz CA
    2007 R1200R
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by GTRider View Post
    The finished pedal installed like this.........
    Next time I need work done on my bike I'm coming to your house.
  1. 2015 1200RT LC - lowered brake pedal
    By 105258 in forum Wetheads
    Last Post: 10-27-2017, 09:09 PM
  2. Knight Design Lowered Footpegs
    By ksb245 in forum Wetheads
    Last Post: 11-03-2016, 02:39 PM
  3. Lowered pegs and brake pedal adjustment
    By beckgr in forum Oilheads
    Last Post: 07-10-2011, 01:34 AM
  4. Lowering '09 RT brake pedal to match lowered pegs.
    By andrewsi in forum Hexheads/Camheads
    Last Post: 05-20-2009, 12:15 AM
