Need to disconnect the cooler return line at the lower left side of the block and replace the 2 crush washers to see if this is my fix. Pretty sure these got butchered and are cause of leak. Approximately how much oil will drain out as I disconnect the banjo bolt, clean up the area, replace with 2 new crush washers and re-torque to spec? Is it just the quantity in the line? Thx
