When I bought my '07 R1200R it came with a BMW battery charger p/n 71 60 7 688 865, a small solid-state device.
The charger has a red LED (marked "0-1/3"), a yellow LED (marked "1/3"), another yellow LED (marked "2/3"), and a green LED (marked "3/3"). When first connected, the red LED illuminates. Then either after a few seconds, the first yellow LED lights up, then it'd be replaced by the second yellow LED, and finally the green LED. After some time (an hour? two?), the cycle would begin again, and eventually process back through all the LEDs. I use the charger when the bike hasn't been ridden for several weeks.
The charger worked easily until just recently. Lately, however, the charging cycle reaches only the second yellow LED ("2/3"); the green LED ("3/3") never illuminates.
The battery (Yuasa YTX14H-BS) is new, and cranks the motor in a healthy manner.
I suspect that something inside the charger has died, but I don't know (and don't know how to know) if that affects only the display LEDs, or is actually limiting the charging in some manner.
Anyone have an ideas here?
