blacque jacque shellacque
Member
I wonder if BMW has any plans to use this new super duper coating “tetrahedrally amorphous carbon" on the wethead cam lobes? It may be a good idea.
I just cannot come to grips with it being maintenance free. It must still benifit from occasional cleaning. So, they are alleging that if Grog, the Ace 850 GS rider buries his rear end in a bog, then a sand dune followed by a mud pit, he need not worry about cleaning the chain? And if he does clean it, then I suppose it is okay to use a power washer. How long is the maintenance free chain warranted for? If I buy one for Annie's F800GS will it be warranted for the life of the bike?
I am starting the rumour that this marks the first step in BMW's transition away from the trouble prone, expensive and heavy shaft drives to reliable, maintenance free, economical and lightweight chain drives.
Sent from my SM-T813 using Tapatalk
I think that will happen!!! right after the find the other halves of the swing-arms they have been saving for a rainy day .
If BMW can do a single-sided belt drive on the F800GT I am sure that they can figure out how to do a single-sided chain drive.
pps I like Paul Glaves wd-40 lube solution...lube the X seals so they live longer...keep grit out of them...key to longer chain life
Looks like that chain is actually produced by Regina in Italy
See Post #18.
BMW has alledgedly mastered a no maintenance chain...Excellent.
Now maybe they could turn their attention to a proper side stand.
The side stand on my K75s have all been just fine. All other BMWs had the side stands designed by the intern during Octoberfest.
I have two K75s and one of them leans over far more than the other. So much so that it takes a 1" puck under it to match the lean angle of the other bike. So far I'm not been able to find any "damage" to explain the difference. That bike needs a spline lube so I will have to pull the center/side stand and will investigate more. The side stand on my K1 is fine as is the one on my K1200RS.
