Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
My 97 RT spends a lot of time in the sun waiting for a ride. Do I need to worry about the Givi Tanklock plastic ring? or is that likely to cause no problems for at least 10 years? Or should I remove it between long trips?
Without knowing what claim Givi may make regarding resistance of the ring to UV deterioration, I will suggest that the rest of the bike would benefit from a cover if it spends extended time in the sun - particularly at higher elevations.
I'll be storing the bike in an enclosed trailer during much of the Winter so I can take it off my poorly maintained, read that icy, street to clear roads. January and February are fairly dry and cold. As long as I can start the bike, I can ride.
My Touratech plastic tank bag ring has suffered no issues in many years of use. I suspect the Givi unit is similarly robust. Leave it on - spend productive time elsewhere.
At the same time, Alienhitchhiker's advice is very good.
I would worry about taking off this lock ring only after I worried about taking off or covering all of the plastic switches on the handlebars and the plastic on the instrument cluster.
