Results 1 to 12 of 12
Thread: K1200S brake pedal photos needed
Hybrid View
    Nibley, UT USA
    Does anyone have close-up photos of the K1300S brake pedal, showing the shape of the lever? A shot showing the orientation or relationship between the brake pedal and master cylinder would help, too. I’m wondering if a K1200S/K1300S pedal can be fitted to a K13GT as part of a peg lowering project.
    Thanks,
    DeVern
    DGerber
    Debbie's Servant Lee's Avatar
    SW Iowa
    This is the best I can come up with.
    Lee
    2016 R1200RS
    MOA # 30878
    Nibley, UT USA
    K1200S brake pedal photo needed
    Thank you, Lee! Looks like the K13S uses the same pedal as the K13GT, and I just verified that at RealOEM. I’m hoping to get a pic of a K12S brake pedal to see if it looks like the photo below, and to assess whether or not that pedal could be fitted to the K13GT. I need to update the thread title, if I can. Thx again,
    DeVern
    DGerber
    Liaison 20774's Avatar
    So you want the main thread title changed? What do you want it to say?
    Nibley, UT USA
    Just change K1300S to K1200S. Thanks!
    DG
    DGerber
    HTH.
    Are we there yet? tonyfr's Avatar
    Apr 2007
    SAT - LAX - LAS
    Quote Originally Posted by GTRider View Post
    Pedals have different part numbers. From the picture I see, they are not the same. This is a brake pedal from a K1300GT. I put Suburban Machinery lowering pegs on my K13GT. I bought a brake lever on eBay and took it to work and the machine shop heated it and bent it 1". Works perfect.
    2009 K1300 GT
    1984 Kawasaki ZX750-E1 Turbo
    1990 Kawasaki ZX600R
    2005 R1200 RT - gone
    Nibley, UT USA
    Correct, the S models use a different brake pedal (35217707302) than the GT models (46717680046), as well as a different stop mechanism. Rather than bend a lever I will likely just modify the stop to get the pedal where I want it. This is the first BMW I’ve had that did not have adjustment on the pedal height, which becomes a factor if one’s ankle has a temporary or permanent range-of-motion limitation.
    Best,
    DeVern
    DGerber
  1. Moto Photos needed - for a fundraiser
    By deilenberger in forum Photography
    Last Post: 04-02-2019, 03:00 AM
  2. Anyone put a GSA brake pedal on a GS?
    By irish in forum Wetheads
    Last Post: 11-28-2017, 12:29 AM
  3. /5 Brake pedal switch?
    By barrettnjones in forum Airheads
    Last Post: 05-09-2015, 04:48 PM
  4. What Is With The Brake Pedal on '09 GSA
    By hojoinsc in forum Hexheads/Camheads
    Last Post: 09-11-2009, 04:57 PM
  5. Brake Pedal Clearance
    By pmdave in forum Airheads
    Last Post: 07-16-2005, 05:18 PM
