Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
I'd first check the rear wheel sensor.
It's an easy test: use the turn signal auto-cancel. That feature uses distance as one of its inputs, and that signal gets sent by the rear wheel sensor. So if your signals don't self-cancel, it's likely the rear wheel sensor.....which also sends the signal for the odometer.
He did not mention anything about the speedometer also not working. If the problem was the sensor or the wiring, the speedometer would also not function.
Chances are 99 out of 100 that if the speedometer is working but the odometers are not, the odometer gears are bad.
