36654
No stand required once all straps are tightened. The straps will keep the bike vertical. The only thing having a stand down can do is damage something. You can use the side-stand to get straps in place, but as soon as you start putting any tension on the off-side strap you will want to raise the stand. Since you have a chock for the front wheel, a stand shouldn't be required at all. Roll it into the chock, strap front and tighten (take up at least 1/2 the travel if not all you can possibly get), strap rear by sub-frame (near passenger pegs) and again, take up as much suspension travel as possible.
If a stand is down, and the bike bounces at all, that shock is traveling straight into the attachment point of the stand with no give.
What this guy said.......
