kf4by
Ol' Hoot
I have a strange problem with my RT. It was running fine last fall after a low speed drop in a parking lot. My son rode it home with no issues but hadn't ridden it since due to his bad experience. This spring I put the battery tender on to bring the battery up to full charge and left it on while I was away for a couple of weeks. Now when I try to start it, the fuel pump will not operate when the side stand is up but the engine will turn over. Except for the Engine Temp and Fuel Level, all indicators are normal. The temp and fuel gauges have every other bar lite as soon as the kick stand comes up when the fuel pump should operate. I disconnected the battery thinking perhaps a voltage spike occurred due to an electrical storm when I was gone and the ECU needed to be reset. No change in the problem. Any suggestions to point me in the right direction would be appreciated.
Thanks in advance!
Stan
Thanks in advance!
Stan
