Nav V in 2013 K1600GTL
TimFarno
Swapping my Nav V between my 2016 R1200GSA and my 2013 K1600GTL and cannot get any Nav wonder wheel function on the 2013 GTL. Can anyone help?
What are you trying to do?
Use the WW to scroll to "Navigation" and from there you should be able to utilize the various functions of the GPS.
Zoom. Page. Compass. Route stats, etc.
Also make sure your contacts are clean.
Joe
wonder wheel and nav 5
I don't know how it would be mounted on the GSA, but are you using the in-dash pop-up connection under the windshield on the K?
Reply
Thanks for the replies. I am trying to use the WW on my GTL to control the scroll, zoom and normal WW functions of the Nav V. The contacts are clean and I am mounting the Nav V in the GTL dash (replacing the Nav IV).
For what you describe, it should be plug and play.
Are you able to scroll to the NAV page?
Once there you should be able to access all the interface functions.
The Big K should recognize that a GPS is installed.
Joe
The wonder wheel option do not work the same between the 2 bikes. While the GS has the ability to roll through zoom and other items, The K16 you have to use the dashboard selection screen on the bike itself, it does not work as fluently as the GS's setup does.
You have to select the Nav screen by using the menu toggle and then when you are at the Nav page, you then use the WW to scroll thru
