anotherbmw
Hi everyone, as the title says, I rebuilt my carbs with new floats, valves, rubber bits and pieces, because they leaked on both sides and the bike was running rough in mid range. Those problems are gone now, but I have an issue with high idling I can't seem to resolve. When warmed up the lowest idle I can get is around 2,000 rpm. Here is what I have done:
-Made sure the cables are not sticking and there is sufficient play
-Completely turned out the idle adjustment screw, it does not even touch the tab of the butterfly valve
-Sprayed starting fluid around the carb intakes with the bike running to check for air leaks, no change in idle observed
What else should I check? Could it be that the butterflies are not installed correctly so they never completely close? I doubt it, but at this point I am looking at everything. I also just ordered the slider springs that are included from the /6 or /7 model on.
Appreciate any input, thanks!
