Hmm. Good to know. I have a Battery Tender input wired directly to the battery, should the adapter not be able to adapt I will splice the output cable from one of my old Battery Tender's to the adapter and run it that way. Thanks for the info, I may not have thought about the canbus system not allowing it to work.
You and me both Stebe. I purchased a Cycle Pump from Best Rest Products. It has alligator clips and a 2-prong SAE connector. I also have a fused SAE outlet to the battery for charging and it runs the pump fine. The pump draws 10amps, and my original intent to use the auxiliary power port was dashed when I discovered the 5-6 amp limit of the ports. Excellent pumps, by the way, for anyone shopping for one. At 10 amps, you don't have to wait all morning for it to fill a tire. Happy trails.
