Results 1 to 9 of 9
Thread: How many spark plug sizes are there for an 03 R1150RT?
    Angry How many spark plug sizes are there for an 03 R1150RT?
    Hi,
    Recently purchased an 03 R1150RT, which I found out that it was made in 10/02. Not sure how that affects things like plug sizes or not. Just got a 14mm thin wall and it doesn't fit, looks to be too small. It also has and old style coil which uses wires that have a spring type fitting that they no longer make wires for. So I had to order a new coil and wires from the dealer ! Starting to think I should kept my Honda.
    Maryland
    I've got a 5/8" spark plug socket that I had a machinist turn down the outside so that it would fit into the recess for the spark plug. There are a lot of spark plug sockets that won't fit into the recess but will fit the spark plug. You need to find one that fits both.
    2004 R1150RT 186,800 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 422,400 BMW miles
    AMA,BMWRA,BMWMOA
    Liaison 20774's Avatar
    Welcome to the forum! I tracked down what type of spark plug should be used in the bike as a NGK BKR7EKC.
    https://www.realoem.com/bmw/enUS/sho...diagId=12_1012
    I found an NGK site here:
    https://www.ngk.com/product.aspx?zpid=9354
    and it appears that the hex size is 16mm...or 5/8" which is a tad smaller across the flats.
    Registered User rogerc60's Avatar
    Oct 2018
    Akron, OH
    Did a factory tool kit come with your bike? If so you should find a spark plug wrench in there that works fine.
    Jul 2018
    Corralitos, CA - Santa Cruz County
    Quote Originally Posted by rogerc60 View Post
    I use this.
    Signature
    Talking
    Thanks to all that offered advice about my spark plug issue !! Ended up as mentioned a 16mm thin wall. So after having to get a new alternator belt and a new coil and wires because the wires on my bike are not made anymore, I finally got the bike put back together and now thunderstorms for the next 2 days. I guess that's the fun of owning an older scoot !!
    Twin Cities - MN
    Quote Originally Posted by wmichal View Post
    Yeah....my newest scoot is a '94, so I get it. I think...
    Brad D. - Member #105766
    '94 R1100RS - Sylvia
    wrench
    Hi,
    use the spark plug wrench that came with your toolkit.
    Quote Originally Posted by RPGR90s View Post
    That is good advice with one big question. How should I attach my torque wrench.
  1. R1150RT Twin-Spark Lower-Plug Problem
    By roger 04 rt in forum Oilheads
    Last Post: 06-03-2015, 03:53 PM
  2. 2004 R1150RT Lower Spark Plug Alternatives
    Last Post: 06-02-2015, 06:41 PM
  3. R1150RT-P spark plug wires
    By K12K12 in forum Oilheads
    Last Post: 12-22-2009, 05:20 PM
  4. spark plug gap
    By paulfinney2 in forum Airheads
    Last Post: 03-28-2007, 03:35 PM
  5. R1150RT Spark Plug Life
    By Mr. Frank in forum Oilheads
    Last Post: 01-03-2006, 12:50 AM
