Results 1 to 12 of 12
Thread: Trailering Question
    Registered User chadwick's Avatar
    Sep 2019
    Spicewood, TX
    Trailering Question
    So, I'm looking at purchasing a 28' enclosed car hauler trailer. While it'll serve many purposes for me, one purpose will be to haul motorcycles for group rides. I'm wondering if anybody has experience with how to most efficiently install anchor points that can be flexible enough to move around depending on how many bikes I'll be hauling at any given time. The trailer is finished out very nicely inside, so I don't want to just go around drilling holes all over the place in it every time I need to move a wheel chock to distribute load differently. So maybe there's some kind of low profile product that can mount to the trailer and then other things can mount to it?
    2019 R 1250 RT
    Registered User cap's Avatar
    Oct 2016
    Fort Collins, CO
    Quote Originally Posted by chadwick View Post
    Check out a product called E-Track. You screw down strips of track having regularly spaced slots. Then, you separately purchase detachable d-rings that you can move around where you need them. The track is raised up just slightly from the surface, so you can roll tires over it easily. Sounds like what you need.
    Cap
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    I have E track on my 18 ft trailer. This is the third trailer this set of track has been mounted on. They are durable, easy to use and as flexible as you like. To aid you in deciding how much track to buy and where to mount it draw up some plans on how you see loading it. Typical arrangement is three strips of track that run the length of the trailer. One strip on each edge and one in the middle.
    Kevin Huddy
    #129265 rinkydink's Avatar
    Apr 2020
    Central Arkansas
    I donít know what type or how heavy bikes youíre hauling
    but I would plan on 4 tie down points per bike. Peace of
    mind is a good thing and Iíve never heard anyone say
    ďI sure wish I wouldnít have secured those bikes so good.Ē
    Better to have them and not need them...Well, you know.
    Linc G.
    Hard work pays off in the future, laziness pays off now.
    Mansfield,MA
    Good thread here-
    https://forums.bmwmoa.org/showthread...orycle-trailer
    Complete with tie-down recommendations.
    Mod Squad
    2009 F800GS 1994 TW200
    Registered User time2ride's Avatar
    May 2017
    Oro-Medonte, Ontario Canada
    E-Tracks are the way to go. I have them on the floor of my trailer and there are ones for the walls as well which I added. Very flexible. Add some removable wheel chocks and you are all set. I painted the ramp with a slip resistant paint (basically has sand in it) which assists with loading/unloading if you cant ride the bike in.
    2005 R1200RT
    Brian
    Registered User ladybmer's Avatar
    Jul 2008
    central TX
    I have ordered this for my Ford Transit 250 van. I've seen it set up in trailers/toy haulers, and it's easy to install.
    https://www.boltiton.com
    One Life. Live it !
    2017 White R1200RT
    Jun 2015
    College Station, TX
    I looked at E-track and decided that I preferred airline track (also called L-track), which is what is used to attach airline seats to the floor. You can see how I installed it on my trailer in this thread
    https://forums.bmwmoa.org/showthread...el-Good-for-RT
    You can install spot mounts as well as track. I bought my track and tie-down rings from US Cargo Control.
    I donít actually tie the bike to the L-track, as the trailer has welded-on loops that work for me, but the L-track is rated for over 1000 lbs. per fitting.
    Cheers, Ken
    2015 R1200GS
    Jun 2009
    Ft Atkinson Wisc
    Nick Kennedy
    Telluride Colorado
    +1 on Rinkydinks tie 'em down real well comment.
    Last summer pulling a long trailer I had a pickup pull out in front of me going from right to left.
    He obviously didn't see me coming.
    I thought he would stop in the intersection, after he saw me coming, so I cut it hard left.
    To my surprise he continued and I, while standing on the brakes, cut it hard right, I thought I was going to hit him in in the door doing about 45 MPH. Just missed his bumper thank god.
    I think the trailers electric brakes saved the day. I run them turned up pretty high, not enough to skid, but high.
    Everything was tied down real well and no damage.
    I was so wigged out, I had to stop for a couple of minutes and walk it off.
    Nick
    Oct 2015
    alexandria, va
    E or L track is great for tiedowns. i also use Condor trailer chocks for the front wheel. they have a low profile mounting base that you can get extras of and put them in the trailer floor permanently in the patterns you will use for bike loading. then the actual chocks themselves can be put on whatever mounting point you need. simple.
    https://www.amazon.com/CONDOR-SC-200...48144234&psc=1
    Marshall
    92 K75s, 94 K75s, 09 K1300s
    May 2015
    South Central PA
    I trailered my GSXR 750 track bike for many years. I don't have an opinion about the track systems but the "method" of tying her down I used is:
    I made nylon web ratchet straps that covered the top 1/4 of the tires- front and rear tires. These are the straps that actually held the bike to the trailer.
    Then I used two ratchet straps to each side of the frame to hold her upright - left and right, near the seat. These did not have to be extremely taught; just enough to hold her from swaying left to right.
    This way I did not rely on compressing the suspension to hold the bike and the straps do not get loose when hitting a large bump. I paid dearly for the suspension setup for my weight so I was not about to compress the suspension unless it was ME compressing the suspension.
    2015 GSA
  1. Trailering an RT
    By curly1150rt in forum Oilheads
    Last Post: 06-09-2020, 05:42 AM
  2. Trailering my RT
    By Olsensan in forum Oilheads
    Last Post: 05-24-2013, 01:51 AM
  3. Trailering RT
    By jstrube in forum Gear
    Last Post: 03-27-2012, 07:08 PM
  4. Next trailering question
    By hlothery in forum Campfire
    Last Post: 06-20-2008, 12:21 AM
  5. Trailering
    By queretaro in forum Airheads
    Last Post: 07-26-2006, 02:04 AM
