r60celo5
hello all.
If I was to send the frame for powder coating, is it a must to remove the drive shaft? what are the risk of leaving it in place? Are there bearings in the U joints that might get damaged by the heat?
its a 1973 R60/5 with 40 000 miles on it and I have stripped it down to the frame. I hear that removing and installing the drive shaft from the swing arm is a pain and requires tools that I don't have, so I am trying to not mess with it and for that reason I had decided to paint the frame.
I called a local reputable shop that does lots of custom paint jobs to get a quote re painting the frame. He strongly recommended that I should powder coat it instead.
Speaking of tools. Is there any member from Westchester NY that can loan me some of these special tools?
Can anyone recommend a reputable shop in Westchester NY to help out with the difficult jobs, say remove and replace the driveshaft, rear seal etc.
thank you.
thank you.
