105643
Howdy, gang. Took the K75 out for a shake down after going through it mechanically and have a new list of items to address. Speedometer needle goes up as speed increases but "sticks" at 40mph.......and stays there. Got the needle to indicate 60mph (I was going much faster......) where it stuck. Various speeds/stops/tapping on the gauge/foul language later and it is stuck back at 40mph. Got to reading threads and pulled the gauge cluster out. The speedometer face plate is "warped" around the shaft and the upper right hand side. Holding down those parts of the face and moving the needle full clockwise, the needle appears to be moving freely and will return back to "zero" on its own.
First question: What should I use to glue the face plate down to the plastic back?
Part 2: The odometer/trip odometer doesn't work. In reading the threads I see people mentioning gears.
Second question: Is the gear replacement a difficult job?
Thanks in advance
Bill Yarian
Thanks in advance
Bill Yarian
