2016 K1300S Battery Suggestion
110125
Gregg L
Looking for a suggestion on a replacement battery for the original in my 2016 K1300S Motorsport. Not sure it’s the issue, but starting there using the KISS rule. My bike acts like it has the hot-start issue with a no-start/dead-battery behavior when restarting hot. Let it sit for a bit and it fires right up. Battery load and voltage checks fine. You should know that it’s got a few farkles like a Sargent heated seat (rarely on), Navigator V, Australian cruise control, etc. I use the cruise often and usually run with the high-beam on. Lithium Ion? Higher aH/CCA rating than the current original 12aH/200 CCA? Thanks in advance!
Gregg L
‘16 K1300S Motorsport
‘14 K1600 GTLE
